- Thank you received: 4
Yes using PWM, but there would be no speed control.Skec wrote: Is there a way to control DC motor without encoder using L298N?
No, it would adjust the speed OK but would not keep the sped when the load changes, and that speed would be dependant on the voltage supply to the drive depending on the motor KV value.Skec wrote: Meaning motor would spin at MAX? or is it possible to set some constant velocity?
