Optical encoders with DC motors
6 years 2 months ago #180211 by Skec
That is fantastic tommylight! I set up L298N through stepconf as PWM. And it runs. I can control DC motor movement through Spindle STOP button. CW and CCW also works. However, I can only turn dc motor ON or OFF, and then it spins on its own. I would love to be able to control it through "+" and "-" in continuous mode using mouse. If it could spin while I keep pressing "+" or "-" with mouse - it would be perfect.
6 years 2 months ago #180219 by tommylight
Does pressing + and - near the spindle button do anything ?
6 years 2 months ago #180222 by Skec
It increases and decreases the speed. If I choose 0 Hz in config, then + or - starts the dc motor CW or CCW depending which one I press. But still, DC motor spins continuously once I press + or -.
6 years 2 months ago #180224 by tommylight
That is exactly how it should work.
If you want to do some more testing, try running some gcode with something like this in it:
% M3 S100 G04 P5 M4 S200 G04 P10 M5 %
That will run the motor CW for 5 seconds at 100 RPM then run CCW for 10 seconds at 200RPM, then stop.
Time to create page: 0.339 seconds
