Optical encoders with DC motors
8 years 7 months ago #108168 by Mike_Eitel
In mini 3 axis you can connect all
3 motor enable signals together.= -2 outputs.
3 home switches together when homing one axis after another. = - 2 inputs.
8 years 7 months ago #108173 by cptX
And here is a video of my implementation.
Two axes in closed loop with a single chip and a PC. Amazing!
8 years 7 months ago - 8 years 7 months ago #108174 by cptX
What do you mean "mini".
Enable signals are usually needed for PWM control. I don't think we can connect them together.
If we put the home switches in series (if I understood correctly your idea) then until the last axis is homed there will be force on the rest axes, something not good!
Last edit: 8 years 7 months ago by cptX.
8 years 7 months ago #108175 by Mike_Eitel
3axis is a small machine (xyz). Up to 9 are possible.
If you want to stay on position, your motors must stay under power as long as you want to do something soon = enable on. All my drivers (3 machines) are always connected to the same output. ( Enable, step, dir).
Lcnc is easy to setup having several home switches in series or parralel to make sequential homing. Well documented in the html...
8 years 7 months ago #108176 by cptX
Hi Mike, I don't understand what you mean?
How can you connect Enable, step, dir of all drivers together?
8 years 7 months ago #108177 by Mike_Eitel
Nop..naturaly not in that way!
Connect all 3 driver-enable signals together.
Plus 3 times the two signals for each motor.
Naturally each motor needs his own step and his own dir.
In sum you control the three motors with 7 output signals..
Mike
Time to create page: 0.154 seconds
