- Thank you received: 4153
tommylight wrote: Your motors are rated at 50W, probably 100 to 120 in short bursts and that is plenty for a light gantry plasma cnc. A while ago i had build a 2X1.25 meters plasma cutter with nema 17 motors and it ran fine, never skipped a beat. Had to change the motors as whoever took a look at it started complaining that the motors are to small.
Use small pulleys on the motors and try to get the ratio from 1:7 to 1:10, you would be surprised at what can those tinny motors do.
Or just mail them to me, and i will name the machine i use them on "the RodW" !!!
cptX wrote: Guys, here is the result of my work over optical encoders and PID control in LinuxCNC the last days:
Tommy, you are full of great ideas so thanks. With a bit of luck I will have forgotten your mailing idea by the time I find where I put them!
