General Help
- tjd
Read a previous thread from last year here but not sure it was relevant.
When I activate X axis servo it jumps (rapid acceleration??) then levels out. Is this to be expected?
I've raised P until oscillation then increased I to remove it but to be honest am floundering around in the dark here!!
What are the best pins to monitor for Halscope?
5i25 + 7i77 (single)
Hurco KM3 CNC (1995) with Servomate Drives
Is the jump due to FF0 or FF1 perhaps? What numbers do you have there?
- tjd
linuxcnc.org/docs/2.7/html/motion/pid-theory.html#_loop_tuning
To be fair I could well have read it wrong - as said above, I'm floundering around in the dark here!!
For FF0/FF1 I have the defaults which I think (I'm not currently at CNC PC) has FF0 at 0 and FF1 at 1
- tjd
At the risk of being a complete rookie here - can you explain what you mean by scaling?
Assuming a velocity-mode servo drive, if a velocity command of 10 units/sec into the 7i77 analogue stage gives 10 units/sec at the motor, then the scaling is correct.
So, then, if an input of 10 units/sec into the PID from the cmd-deriv input (or internally calculated) when mutiplied by the FF1 Gain (of 1) you should get exactly what is requested as the output velocity.
The PID output is just the sum of 6 terms:
FF0 * position command
FF1 * velocity command
FF2 * acceleration command
PGain * position error
IGain * integral of position error
DGain * derivative of position error.
P, I and D do have units, but you never really know what they are, so they always need tweaking. But FF0, FF1 and FF2 have the same units as the machine, so a gain of 1 is only correct if the output scaling gives the same units.
- tjd
So with that in mind, should I continue with the 'Increase P till oscillation' then increase I to stop oscillation.....' method to tune the axis?
On another HAL PID Tutorial it uses Halscope to get the axis tuned correctly - is this something you're familiar with?
gnipsel.com/linuxcnc/tuning/servo.html
No, because nothing ever says to do thatSo with that in mind, should I continue with the 'Increase P till oscillation' then increase I to stop oscillation.....' method to tune the axis?
Some guides say to increase _D_ to kill the oscillation, but none ever say to use I, as far as I know.
I think this is the best way. It lests you see exactly what effect each parameter is having.On another HAL PID Tutorial it uses Halscope to get the axis tuned correctly - is this something you're familiar with?
No, because nothing ever says to do that{edit} Actually, it does say that, doesn't it? I have never heard of that approach, and I would be surprised if it worked well.
- tjd
With the halscope method, what are the pins/signals/parameters I need on the scope? my setup didn't reflect quite the same pin names.
I'm using 5i25 + 7i77
