fanuc motor questions
- Yannis
- Thank you received: 4
28 Jun 2018 17:32 #113005
by Yannis
fanuc motor questions was created by Yannis
Hi linux users
i purchase a CMS MAXIMA 4 axis cnc for marble
the machine have FANUC GE SERIES 180i-M CNC controller
when i open the electric cabinet i saw 4 fanuc items and i believe that it was the 4 servo amplifiers
but i was wrong
the 2 items are power supply module A06B-6077-H111
The other 2 items are servo amplifiers modules one A06B -6096-H105 and one A06B-6096-H101
So the question is this
Can i use this amlifiers with linux cnc
Is there anyone with experience in this fanuc items
Any pointing direction is very appreciated
thanks
but i was wrong
thanks
- Thank you received: 4652
28 Jun 2018 20:00 #113018
Replied by andypugh on topic fanuc motor questions
I had a quick look and couldn't tell.
The drive manual references the "Type A" and "Type B" interfaces between the drives and the CNC, but gives no details (that I spotted) about what that means.
The following user(s) said Thank You: Yannis
- fixer
- Thank you received: 27
28 Jun 2018 20:16 #113022
by fixer
Replied by fixer on topic fanuc motor questions
Those are Fanuc Alpha drives. They use proprietary communication protocol with both, the controller and with encoders.
Currently there is no interface card that you could use.
- Yannis
29 Jun 2018 00:59 #113045
by Yannis
Replied by Yannis on topic fanuc motor questions
The motors are fanuc a06b-0143-b077 #7008
At your opinion what is the best approach?
Sud i use the motors with different drivers (granite devises)
or sud i look for new drivers and motors(Chinese?)
29 Jun 2018 12:16 #113085
Why not use the existing Fanuc controller?
- Yannis
30 Jun 2018 05:18 #113122
by Yannis
The reasons are:
1) i don't now if the machine was in working condition
2) the machine have cables cut in 3 places,near the mane electric cabinet, near the cable chain and near the portable electric cabinet
3) i don't now anything about Fanuc controller
4) I don't have post processor for the Fanuc controller
5) I don't have the electric schematic for the machine
- emcPT
- Thank you received: 95
01 Jul 2018 20:52 #113185
by emcPT
Replied by emcPT on topic fanuc motor questions
If they are 3 phase motors and you do not know how the encoders work, my suggestion is:
Replace the existing encoders with incremental ones; use another servo drive.
I have done this in the past with okuma ones. Never reached the same performance as the original ones, but I got a working machine. More, I got a working machine were I could fix in case of troubles.
01 Jul 2018 22:07 #113192
This document
github.com/rene-dev/stmbl/blob/master/do...tting%20Started.adoc
Says that the STMBL drive can interface with the Fanuc serial encoders.
There is also a module for the Mesa cards that can read (at least some of) the Fanuc encoders.
Do you know the voltage and power ratings of the motors ?
- Yannis
02 Jul 2018 04:25 #113203
by Yannis
In the 3 main x,y,z axis the motors are 2.8kw. The label of it is attached
In the c axis there is a very small maybe 100-200 watt
where sud i look for encoders and drivers
- Yannis
02 Jul 2018 04:27 - 02 Jul 2018 05:08 #113204
by Yannis
andypugh There is also a module for the Mesa cards that can read (at least some of) the Fanuc encoders.
dear andypugh is this some commercial product or is it something to build by your self?
Last edit: 02 Jul 2018 05:08 by Yannis.
Time to create page: 0.333 seconds
