fanuc motor questions
- Yannis
- Thank you received: 4
14 Jul 2018 06:16 #114159
by Yannis
Replied by Yannis on topic fanuc motor questions
Ok here is how i think i sud act
i want to by mesa components conservative
i will by one piece of 5i24 with the proposed daughter card and 1 pcs of 8i20
(i think that is what needed)
then on a bench i will connect each one of the motors to test the connectivity
but also the condition of the motor it self
Any thoughts on that?
- Yannis
14 Jul 2018 06:22 #114160
by Yannis
also i forgot to mention that on the c axis i have this motor of 0.2 kw
- Yannis
14 Jul 2018 06:23 #114161
by Yannis
- Thank you received: 4652
14 Jul 2018 09:57 #114165
You could, first, try reading the encoders with your existing Mesa hardware. This would require a custom firmware with a Fanuc encoder on the 7i77(?) expansion port.
Replied by andypugh on topic fanuc motor questions
- Yannis
14 Jul 2018 10:52 #114166
by Yannis
The 5i25 and 7i77 is on a production machine and i prefer to start with new mesa cards
- Yannis
13 Sep 2018 19:03 #117475
by Yannis
Hi
anyone now how many pole have the a12\ 3000 fanuc motor
i try to find it in the manual on the link with no result
jamet.com/Technical/Fanuc/DRIVES/a_series_servo_descman.PDF
13 Sep 2018 19:25 #117477
You should be able to count them by turning the shaft with a small current applied to one pair of windings.
The following user(s) said Thank You: Yannis
- Yannis
14 Sep 2018 11:12 #117515
by Yannis
Hi
what i can not understand is that for the fanuc b-0,5/3000 you can find all the info on the label (previous picture ) and for a larger motor like the a12/3000
you have to use an instrument to find the poles of the motor
also i can not find in the manual the wiring diagram for the connector
strange ...
strange ...
Time to create page: 0.153 seconds
