fanuc motor questions
- Yannis
- Thank you received: 4
02 Jul 2018 04:44 #113205
by Yannis
Replied by Yannis on topic fanuc motor questions
the label of the drivers
02 Jul 2018 09:42 #113213
Mesa cards are commercial.
store.mesanet.com
linuxcnc.org/docs/devel/html/man/man9/hostmot2.9.html#BiSS
It looks like you have two channels of 750W and 2 channels of 4.75kW.
Neither the Mesa 8i20 or the STMBL are big enough to replace the 4.75kW drive if it does need to be that big. Both are rated at about 2.2kW, so might be able to run the motors, but perhaps not at original speeds.
The Fanuc hardware is pretty nice, it seems a shame not to use it. Does the controller power up?
Looking on eBay completed listings it looks like you might be able to get some money back for the Fanuc drives.
Replied by andypugh on topic fanuc motor questions
andypugh There is also a module for the Mesa cards that can read (at least some of) the Fanuc encoders.
dear andypugh is this some commercial product or is it something to build by your self?
store.mesanet.com
- Yannis
02 Jul 2018 11:02 #113217
by Yannis
I now that the fanuc system is professional solution But even if is in running condition as i describe earlier there are some problems
first of all all the cables are cut in several places and from the time bin i don't have any electric schemes of the machine
second the machine have several switches and sensors in bad shape
third i don't now how i can find a running program and a post processor for that
To resume what is on the mane electric cabinet:
power supply 13.2 kw
servo amplifier 9,5kw it looks like 2 motors are connected on it
servo amplifier 4,75kw
servo amplifier 0,75kw
kind reminder the motors are 2.8kw
- Yannis
02 Jul 2018 11:04 #113218
by Yannis
motor label
03 Jul 2018 14:23 #113319
Well, the motor label seems to be inside the parameters of the STMBL, Mesa 8i20 or (Possibly, the rated voltage is a little high, the Pico brushless amp).
Is there a part number visible on the encoder housings?
Do you already have a LinuxCNC system? What hardware do you already own?
The first thing to try (I think) is to see if you can read position information from the motors.
- Yannis
04 Jul 2018 05:29 #113382
by Yannis
I have a INTERMAC machine witch i retrofit with the help of this forum .I use 5i25 and7i77 combo there
forum.linuxcnc.org/38-general-linuxcnc-q...try-machine-progress
- Yannis
04 Jul 2018 05:31 - 04 Jul 2018 05:32 #113383
by Yannis
is this what we are looking for?
Last edit: 04 Jul 2018 05:32 by Yannis.
- Yannis
04 Jul 2018 05:34 #113384
by Yannis
motor
- Yannis
04 Jul 2018 05:41 #113385
by Yannis
i already check the pico system
there answer is
"Our servo drive is capable of producing up to 20 A peak.
The A06B-0143 motor has a stall rating of 15 A, but the peak
rating is 43 A. So, you could develop the continuous rating
of the motor with our servo amp, but less than half the peak
rating."
not very clear to me (limited knowledge)
there answer is
rating."
- emcPT
- Thank you received: 95
04 Jul 2018 06:22 #113390
by emcPT
Replied by emcPT on topic fanuc motor questions
It means that at the end you will have limited performance from the system. Probably not able to get the original acceleration provided by the fanuc servo drive.
Be aware that most of commercial (lower cost - not low cost) servo drives are not able to reach the 43A. The 20A from the pico servo drive is "standard" among many drives.
Time to create page: 0.176 seconds
