Lost Step Counter
- DieselJoe
8 years 2 weeks ago #118946
by DieselJoe
Replied by DieselJoe on topic Lost Step Counter
Hi I get nowher at this point. I spent 3 days on it...
I know a bit programing in C (arduino), but It's is to much to chew for me...
Python langage, HAL, linuxcnc structure ...
At this point I have a custom panel on the side of main screen.
I can display two interesting things:
for X axis for instance:
halui.axis.0.pos-commanded (which seems to reset to Zero when homing)
xpos-cmd (which seems to remain very absolute)
with this we can imagine a variable which make the difference and give the deviation
"deviation" = "X" - "absoluteX" - "previous deviation"
and a reset button to give to "previous deviation" variable the value of "deviation"
???!!!???? HELP
???!!!???? HELP
8 years 2 weeks ago #118950
Replied by andypugh on topic Lost Step Counter
Have you managed to get the file that I gave you to load as a HAL module?
It won't display anything until it is connected up in HAL.
- DieselJoe
8 years 2 weeks ago #118951
by DieselJoe
I believe YES, I think a mistake in the copy/past in your post introduced a little mistake.
p1 = .......JOINT.pos-cmd right? (joint was missing)
now linuxCNC run, and I see this new pins in the HalMeter
nothing appears when I force a Home, and the halMeter remain at "0"
But I think it is an improvement yet
I start understanding how it works... maybe...
8 years 2 weeks ago #118952
Do you have the HAL pins connected?
- DieselJoe
8 years 2 weeks ago #118953
by DieselJoe
Sh...t I forgot this.
I was so happy to succeed running linuxcnc eventualy.
I do it right now
I do it right now
- DieselJoe
8 years 2 weeks ago #118954
by DieselJoe
Now connected, I have your popup window working.
It show up asap I move the axis and just repeat the position.
Can you check the code and or the connection syntax?
But it's an improvement for my understanding of the system yet !
thank you
thank you
Time to create page: 0.193 seconds
