Lost Step Counter
8 years 2 weeks ago #118726 by andypugh
Replied by andypugh on topic Lost Step Counter
This seems to work.
Save this as a file called "miss_step" and make it executable.
#!/usr/bin/python import hal, time import sys from Tkinter import * import tkMessageBox root = Tk() root.withdraw() h = hal.component("miss_step") count = 1 for opt in sys.argv[1:]: (dummy, count) = opt.split("=") if dummy != "count": count = 1 pins = [] for i in range(int(count)): p1 = "axis.%i.pos-cmd" %i p2 = "axis.%i.motor-pos-cmd" %i d = 0 t = [p1, p2, d] pins.append(t) h.newpin(p1, hal.HAL_FLOAT, hal.HAL_IN) h.newpin(p2, hal.HAL_FLOAT, hal.HAL_IN) h.ready() try: flag = False while 1: time.sleep (1) for t in pins: if h[t[0]]-h[t[1]] != t[2]: flag = True t[2] = h[t[0]]-h[t[1]] if flag == True: flag = False message = "" for t in pins: message = message + t[0] + " = %f\n"%t[2] ret = tkMessageBox._show("Homing Position Differs", message, tkMessageBox.QUESTION, tkMessageBox.OK) root.update() except KeyboardInterrupt: raise SystemExit
Then load it in the HAL file
loadusr miss_step count=3
Then in the HAL file connect the pins for each axis
net check0 miss_step.axis.0.pos-cmd axis.0.pos-cmd net Xpos miss_step.axis.0.motor-pos-cmd
Or whatever signal axis.0.motor-pos-cmd is linked to
8 years 2 weeks ago #118727 by DieselJoe
Replied by DieselJoe on topic Lost Step Counter
Thank you.
Incredible.
I am not familiar with add-ons modules on linuxcnc, but I will work on it this weekend
8 years 2 weeks ago #118889 by DieselJoe
Sorry I'm newbie in Hal files.
I tried what you told me , and also i'am trying to read and understand documents on HAL files.
I made the miss_step file, made it executable (chmod -x right ?)
positioned the file in /.../linuxcnc/configs/ma-machine
then added in custom.hal :
Is it the right procedure ?
I have a lot of errors and linuxcnc doesn't want to launch
8 years 2 weeks ago #118890 by andypugh
I think that the python file needs to go in usr/bin/linuxcnc
(or you can give the complete path to the file in the loadusr statement)
Can you attach the error listing?
8 years 2 weeks ago #118892 by DieselJoe
Debug file information:
./custom.hal:3: Warning: File contains DOS-style line endings.
./custom.hal:4: Pin 'miss_step.axis.0.pos-cmd' does not exist
7165
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
8 years 2 weeks ago #118898 by DieselJoe
I have to mention that I am running this test on a small laptop which is not my actual cnc PC, and has no real parallel port.
Linuxcnc version 2.7.8
Time to create page: 0.347 seconds
