Lost Step Counter
6 years 6 months ago #164620
Replied by andypugh on topic Lost Step Counter
Possibly you need "loadusr -W" in the line that loads the component, so it waits for the component to be loaded before moving on to the rest of the HAL file.
The following user(s) said Thank You: MartyJ
- MartyJ
- Thank you received: 13
6 years 6 months ago - 6 years 6 months ago #164651
by MartyJ
Replied by MartyJ on topic Lost Step Counter
Ok, looks like that part is resolved. Move AndyPugh's:
lines to being in the postgui HAL file.
The error is now that the pin "joint.0.motor-pos-cmd" is already connected to the signal 'x-pos-cmd' which is part of my main HAL setup. Is there a way to do this using the "x-pos-cmd" signal, my understanding being that once the signal is set up, we can use it many times?
If I change it to this:
then the error I get is that x-pos-cmd isn't a pin.
net check0 miss_step.joint.0.pos-cmd joint.0.motor-pos-cmd
net Xpos miss_step.joint.0.motor-pos-cmd
net check0 miss_step.joint.0.pos-cmd x-pos-cmd
Last edit: 6 years 6 months ago by MartyJ.
6 years 6 months ago #164654
The signal is always the first thing after a net. But you can use the same signal in many net commands.
What you can't do is net a signal to a signal.
So I think you want
So I think you want
net x-pos-cmd miss_step.joint.0.pos-cmd
- MartyJ
6 years 6 months ago - 6 years 6 months ago #164705
by MartyJ
Thanks, gents. Much appreciated. I got this going, I just view them with Halmeter, and it's helped me diagnose some step timing issues.
my version of miss_step script:
And the connections in my custom_postgui.hal file:
#!/usr/bin/python
import hal, time
h = hal.component("miss_step")
h.newpin("mot_off_x", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("joint_x", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("lost_x", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
previous_offset_x = 0.00
allowed_offset = 0.001
try:
while 1:
time.sleep(1)
# X
# make difference between previous offset and current offset, print the deviation if > specified
if (h['mot_off_x']-previous_offset_x) >= allowed_offset or (h['mot_off_x']-previous_offset_x) <= -allowed_offset:
h['lost_x'] = round(h['mot_off_x']-previous_offset_x, 3)
previous_offset_x = h['mot_off_x']
except KeyboardInterrupt:
raise SystemExit
net motoroffsetx miss_step.mot_off_x <= joint.0.motor-offset
net joint_x miss_step.joint_x <= joint.0.pos-cmd
- Jeff_in_Wa
- Thank you received: 5
5 years 4 months ago #212082
by Jeff_in_Wa
Replied by Jeff_in_Wa on topic Lost Step Counter
So, I have spent a lot of time trying to get the original code to work using gmoccapy. I have it working but with unexpected results.
When I home the machine, I get the message box which shows the value in X. Perfect.
I thought, great, now I can load some gcode, run it and see which axis is having problems.
When I move the gantry to set up the 0,0,0 points, the machine takes off on it's own. A miss_step message box
pops up with some random number.
I can't even stop the jog unless I hit the e stop.
I thought, maybe this is a compatibility issue with gmoccapy. Maybe not.
Here is my code:
miss_step file:
#!/usr/bin/python
import hal, time
import sys
from Tkinter import *
import tkMessageBox
root = Tk()
root.withdraw()
count = 1
for opt in sys.argv[1:]:
(dummy, count) = opt.split("=")
if dummy != "count":
count = 1
pins = []
for i in range(int(count)):
p1 = "axis.%i.pos-cmd" %i
p2 = "axis.%i.motor-pos-cmd" %i
d = 0
t = [p1, p2, d]
pins.append(t)
h.newpin(p1, hal.HAL_FLOAT, hal.HAL_IN)
h.newpin(p2, hal.HAL_FLOAT, hal.HAL_IN)
h.ready()
try:
flag = False
while 1:
time.sleep (1)
for t in pins:
if h[t[0]]-h[t[1]] != t[2]:
flag = True
t[2] = h[t[0]]-h[t[1]]
if flag == True:
flag = False
message = ""
for t in pins:
message = message + t[0] + " = %f\n"%t[2]
ret = tkMessageBox._show("Homing Position Differs",
message,
tkMessageBox.QUESTION, tkMessageBox.OK)
root.update()
raise SystemExit
Here is my custom_postgui.hal code:
# -- AndyPugh zero checker connections
#net check0 miss_step.axis.0.pos-cmd axis.x.pos-cmd
#net Xpos miss_step.axis.0.motor-pos-cmd
Here is the custom.hal code:
#loadusr -W /home/jeff/Desktop/Mauer-Mill/miss_step count=3
I not only cannot get this code to work without taking over the machine during jogs, but wonder if
there is a way to monitor the two Y joints? I don't have any idea how to do that. It is there that I
am having problems. X and Z are fine. I can't keep the two Y's on my gantry machine to stay in sync.
Thanks much
Here is my code:
miss_step file:
#!/usr/bin/python
import hal, time
import sys
import tkMessageBox
root = Tk()
root.withdraw()
count = 1
count = 1
pins = []
d = 0
t = [p1, p2, d]
pins.append(t)
h.ready()
try:
flag = False
while 1:
time.sleep (1)
for t in pins:
flag = True
if flag == True:
flag = False
message = ""
for t in pins:
message,
root.update()
raise SystemExit
Thanks much
- BeagleBrainz
- Visitor
5 years 4 months ago #212084
by BeagleBrainz
Replied by BeagleBrainz on topic Lost Step Counter
I made a reply in the other thread, mentioning you may need to look at joints rather axes (plural of axis)
Time to create page: 1.812 seconds
