XHC-WHB04B-6 LinuxCNC not working
6 years 3 months ago #173590 by 00alkskodi00
After comment in my HAL
#net joint-select-a halui.axis.x.select #net joint-select-b halui.axis.y.select #net joint-select-c halui.axis.z.select
linuxcnc start normal, but a can not move with X Y Z axis on pedant
6 years 3 months ago #175895 by crowloy
Having an issue with is-mdi already being assigned. I've inserted a pic of the error. The link to the github page does not include a example .hal file.There is a kind of readme md file for the example hal file, but the pin definitions are all jumbled
6 years 3 months ago #176315 by alkabal
Hi
I think you simply need to remove the "setp MDI-mode halui.mode.is-mdi" from you main ini file that is not really used.
6 years 2 months ago - 6 years 2 months ago #178831 by romeofox
The hal component (xhc-whb04b-6) seems to react too slowly or not correctly with my machine. For the knobs this is inconspicuous, but during the normal rotation of the handwheel much too few impulses are transmitted (e.g. whb.axis.0.jog-counts).
I tried it with V2.8 and V2.9 as well as Debian 9 and Debian 10.
But maybe it is also due to the usb controller of my mainboard J5005-ITX.
Is this known/is there already a solution for this?
Regards, Robert
Last edit: 6 years 2 months ago by romeofox.
6 years 2 months ago #178958 by satiowadahc
You may need to post more of your INI File.
However here's mine:
# Jog wheel and axis selection button
net jog-x axis.x.jog-enable <= xhc-hb04.jog.enable-x
net jog-y axis.y.jog-enable <= xhc-hb04.jog.enable-y
net jog-z axis.z.jog-enable <= xhc-hb04.jog.enable-z
6 years 2 months ago #178959 by satiowadahc
Odd, a page didn't seem to load and definitely replied to the wrong post.
Time to create page: 0.075 seconds
