XHC-WHB04B-6 LinuxCNC not working
7 years 9 months ago #124922 by nonkeldw
Hi
I bought me a wireless pendant for using with LinuxCNC. Type: XHC WHB04B-6.
After surfing on the internet I found a GitHub and some threads about this pendant. After the build of the example code, i tested the connection with the pendant. The PC is not able to connect with the wireless stick over the USB connection.
Please find below the already read threads:
forum.linuxcnc.org/24-hal-components/317...hc-whb04b-4?start=20
forum.linuxcnc.org/10-advanced-configura...pulse-coder?start=20
GitHub:
github.com/rubienr/machinekit/blob/featu...c-whb04b-6/README.md
github.com/ctbenergy/linuxcnc/tree/2.7-f...r_comps/xhc-whb04b-6
If you want, I can chare my binary file
Is there anyone that can help me with get this working for LinuxCNC?
Thanks!
7 years 9 months ago #125179 by andypugh
Which version of linuxCNC are you using?
Does the problem seem to be with LinuxCNC or with the OS wireless connection?
7 years 9 months ago #125194 by nonkeldw
Hello
Thanks for your answer. I use LinuxCNC 2.8.0.
At this time it is a HALL component problem. The buttons from the pendant are working ( I checked this with the Hall meter) but the MPG doesn't work... when i check this with the hall meter, the value stays zero. I used the template from Github: github.com/ctbenergy/linuxcnc/blob/2.7-f...ple-configuration.md
I changed al the AXIS tot Joints.
But that doesn't the trick.
7 years 9 months ago #125197 by andypugh
Which pins are you looking at with halmeter? Is it possible that the MPG has more than one set of output pins?
(Looking at the docs, though, it does seem pretty clear that it should be "jog-counts")
7 years 9 months ago #125200 by nonkeldw
Joint.0.jog-counts. Stay 0..
7 years 9 months ago #125201 by andypugh
What is it connected to?
Time to create page: 0.151 seconds
