XHC-WHB04B-6 LinuxCNC not working
01 Feb 2019 19:17 #125487 by nonkeldw
Replied by nonkeldw on topic XHC-WHB04B-6 LinuxCNC not working
Hello
Thanks, the machine is now reacting on the pendant. But the scale is not yet correct interpreted. The scale stay on 2, it is not changing with the button. When I run the code in debug mode the driver reacts on the change... but there is no change in LinuxCNC
13 Feb 2019 12:54 #126335 by andypugh
Replied by andypugh on topic XHC-WHB04B-6 LinuxCNC not working
This sounds like a HAL connection problem to the jog scale inputs
19 Jun 2019 22:27 #137312 by marcobc
Replied by marcobc on topic XHC-WHB04B-6 LinuxCNC not working
can you please share binary file? thank you.
05 Sep 2019 18:46 - 05 Sep 2019 18:47 #144264 by Talla
Replied by Talla on topic XHC-WHB04B-6 LinuxCNC not working
Hello,
I have Debian 9 and LinuxCNC 2.8.
How can I easily install the XHC-WHB04B-6 driver?
Greetings Peter
Last edit: 05 Sep 2019 18:47 by Talla.
05 Sep 2019 23:31 #144289 by andypugh
If you have LinuxCNC then you probably already have the driver:
linuxcnc.org/docs/2.8/html/man/man1/xhc-hb04.1.html
06 Sep 2019 14:55 #144385 by Talla
So I tried, but it does not connect.
The ID is 10ce:eb93 and not as specified 10ce:eb70.
What can I do ?
06 Sep 2019 15:07 #144386 by andypugh
You could try recompiling
github.com/LinuxCNC/linuxcnc/blob/master...mps/xhc-hb04.cc#L822
There may be useful ideas in this discussion:
bbs.archlinux.org/viewtopic.php?id=204964
06 Sep 2019 15:09 #144387 by andypugh
A search for "eb93" on this forum found:
forum.linuxcnc.org/24-hal-components/361...hon-component#143708
06 Sep 2019 15:27 #144389 by Talla
Thank you
How can I recompile the driver only?
Is there a manual?
Unfortunately I am not so fit in terms of Linux.
I would like to try .... but how ?
github.com/ctbenergy/linuxcnc/blob/2.7-f...04b-6/xhc-whb04b6.cc
08 Sep 2019 09:35 #144506 by Talla
Hi
I compiled the driver to LinuxCNC 2.9. There are still some bugs but I am confident.
Thanks, Greetings Peter
Time to create page: 0.376 seconds
