XHC-WHB04B-6 LinuxCNC not working
- MarcoGaspar
18 Apr 2020 20:28 #164505
by MarcoGaspar
Replied by MarcoGaspar on topic XHC-WHB04B-6 LinuxCNC not working
First i use www.talla83.de/xhcwhb04b.html .... but i think that i have tested all that i find :(
I put the "sf" args and is the same error.
what file i have to rename to "xhc-whb04b-6.hall" ?
- alkabal
- Thank you received: 52
18 Apr 2020 22:47 - 30 Jun 2020 21:14 #164533
by alkabal
Replied by alkabal on topic XHC-WHB04B-6 LinuxCNC not working
The driver is now integrated in 2.9 (master) from 2 days ago only.
Basically you only need to download this file : (untested wget command...)
Edit your ini for adding
and add to HAL section (i think before POSTGUI_HALFILE)
For RUN IN PLACE ONLY :
sudo cp /home/pi/emc/debian/extras/lib/udev/rules.d/*.rules /etc/udev/rules.d
you need to adapt this command with your home directory name (replace /pi/) and the source folder name (replace/emc/)
Or if the rules file is missing you can try to create one and copy past the above code:
sudo nano /etc/udev/rules.d99-xhc-whb04b-6.rules
Reboot computer before trying to use
Ps : maybee someone can add the needed stuff to stepconf and pncconf ??
cd your_config_directory
wget -O xhc-whb04b-6.hal https://github.com/LinuxCNC/linuxcnc/raw/master/src/hal/user_comps/xhc-whb04b-6/example-configuration.mdEdit your ini for adding
[HALUI]
MDI_COMMAND=(debug,macro0)
MDI_COMMAND=(debug,macro1)
MDI_COMMAND=(debug,macro2)
MDI_COMMAND=(debug,macro3)
MDI_COMMAND=(debug,macro4)
MDI_COMMAND=(debug,macro6)
MDI_COMMAND=(debug,macro8)
MDI_COMMAND=(debug,macro9)
MDI_COMMAND=(debug,macro10)
MDI_COMMAND=(debug,macro11)
MDI_COMMAND=(debug,macro12)
MDI_COMMAND=(debug,macro13)
MDI_COMMAND=(debug,macro14)
MDI_COMMAND=(debug,macro15)
MDI_COMMAND=(debug,macro16)and add to HAL section (i think before POSTGUI_HALFILE)
HALFILE = xhc-whb04b-6.halFor RUN IN PLACE ONLY :
# xhc-whb04b-6 mpg pendant
ATTR{idProduct}=="eb93", ATTR{idVendor}=="10ce", MODE="666", OWNER="root", GROUP="plugdev"Reboot computer before trying to use
Last edit: 30 Jun 2020 21:14 by alkabal.
The following user(s) said Thank You: pommen
- MarcoGaspar
19 Apr 2020 08:56 - 19 Apr 2020 09:41 #164612
by MarcoGaspar
I get the same error
Working now....
did chmod +x xhc-whb04b-6
Now if i put the step pot on lead position the pendant stop works, need to close axis to get it back.
loading in halrun when slect the lead position get this error: pndnt failed to interpret axis code axisCode={}
Working now....
Last edit: 19 Apr 2020 09:41 by MarcoGaspar.
- alkabal
19 Apr 2020 10:40 #164621
by alkabal
Can you past the result or picture from
watch -n0.4 halcmd show pin whb.*
chmod +x is normally only needed with copy past binaries
i'm unsure but i hope a Run in place with sudo make setuid or a instal from buildbot do automatically the chmod +x
- MovT
- Thank you received: 7
19 Apr 2020 11:00 #164622
by MovT
If you add confs to the udev you need to run:
to reload the confs and database.
Replied by MovT on topic XHC-WHB04B-6 LinuxCNC not working
udevadm control -Rto reload the confs and database.
- alkabal
19 Apr 2020 11:50 #164628
by alkabal
Hi
I never do this ??
Not needed after reboot ?
I never do this ??
- bbsr_5a
- Thank you received: 106
19 Apr 2020 12:30 #164633
by bbsr_5a
Replied by bbsr_5a on topic XHC-WHB04B-6 LinuxCNC not working
you can do a autoreload for the XHC HAL
then you do not need to reboot or stop the machne
just press the Enable XHC and it comes back up
HOW to DO
MAKE a Coustom M-code that holds the loadup Command line
Like M188
#!/bin/bash
# file to reload XHC
halcmd loadusr -W xhc-hb04 -I myini.ini -H
exit 0
HOW to DO
Like M188
#!/bin/bash
exit 0
- alkabal
19 Apr 2020 15:55 #164648
by alkabal
I suspect your knowledge is for xhc-hb04 and not for xhc-whb04b-6
I never need to disable/enable this driver pendant ???
HOW to DO
Like M188
#!/bin/bash
exit 0
- MarcoGaspar
20 Apr 2020 10:00 - 20 Apr 2020 10:30 #164811
by MarcoGaspar
-Is normal have delay (about 2/3 seconds) between the coordinates from computer to pendant?
-How can i remap macro buttons to for example macro1 turn on/off the flood?
-I have stepper motors and when moving the axis with the keyboard keys, it moves smooth but when moving with pendant it is not smoothing the machine vibrates.
-When starting linuxcnc (axis) with the keyboard i can move the machine every where, but if i move with the pendant i can't move to x+ / y+ or z+...... i have to do homing first.
Last edit: 20 Apr 2020 10:30 by MarcoGaspar.
- alkabal
20 Apr 2020 22:31 - 20 Apr 2020 22:35 #164894
by alkabal
- I think no, display are not really fast, but 2 to 3 seconds seem to be too high.
- for signal that need toggle you can do this with a standard macro button but you need to use toggle2nist
linuxcnc.org/docs/html/man/man9/toggle2nist.9.html
I have try and i'm not satified even adding a debounce
linuxcnc.org/docs/html/man/man9/debounce.9.html
This is the reason for hardcoded some enhanced function like the mist/flood/lube
You can remove mist/flood/lube config (and other hardcoded function) and use regular macro button for what you want.
You can't use enhanced function with standard macro button without external trick or change source code and compiling.
- Have you tried Step/continuous mode ? different speed ? (i'm not expert but is your acceleration settings not too high ?)
- i never use keyboard for jog and never use another pendant so i can't confirm if this is normal or not.
I'm not the first authors and i don't know/understand 100% of the code... I have only rework some stuff and add more functionality (original one is from Rubien Raoul you can found the code inside Machinekit)
I'm sure more work can be done for clarifying/correcting some parts of the code.
Last edit: 20 Apr 2020 22:35 by alkabal.
Time to create page: 0.586 seconds
