XHC-WHB04B-6 LinuxCNC not working
- jonch919
13 Nov 2019 01:38 #150261
by jonch919
Replied by jonch919 on topic XHC-WHB04B-6 LinuxCNC not working
Aah got it.. I assumed there were newer versions since you mentioned updating the driver in october.
I see now that your driver is for the 4-axis version. I have the 6-axis. Not sure where to proceed now.
- satiowadahc
- Thank you received: 12
13 Nov 2019 02:11 #150263
by satiowadahc
Replied by satiowadahc on topic XHC-WHB04B-6 LinuxCNC not working
Welp needed a study break. I don't have my mill/pendant at home to test this with but try this one. Because the forums don't allow certain extensions, change the extension to .cc let me know if it compiles (:
The following user(s) said Thank You: jonch919
- jonch919
13 Nov 2019 17:41 #150315
by jonch919
Thank you! I will try it tonight.
- randypetersen
- Thank you received: 15
07 Dec 2019 19:00 - 07 Dec 2019 19:01 #152273
by randypetersen
Thanks again for everyone's help... Very helpful device for my CNC.
Replied by randypetersen on topic XHC-WHB04B-6 LinuxCNC not working
Last edit: 07 Dec 2019 19:01 by randypetersen. Reason: adding video
- satiowadahc
07 Dec 2019 21:07 #152291
by satiowadahc
That's Exciting to see you got it working! I plan on getting back to working on the driver for this next week... if I don't get pulled to somewhere else....
- sdwyer
02 Jan 2020 03:38 #153767
by sdwyer
Replied by sdwyer on topic XHC-WHB04B-6 LinuxCNC not working
Hi Guys,
I've just got the 4 axis version of this MPG for my first LinuxCNC build....
I hope to do some testing in the next 2 weeks with this and a Mesa 7i95 ethernet board. Thanks for all your hard work! I'm looking forward to the continued progress. Once I get my system up and running I might be able to lend a hand?
Cheers!
Shaun
Cheers!
Shaun
- satiowadahc
02 Jan 2020 03:59 #153770
by satiowadahc
Hi Shaun,
If you want to continue development on it, grab the code from my github, it seems I'm going to drop the project for this pendant as it violates a few FCC rules, and our shops been told to discontinue use of it. If you have any questions or want help along the way I may be able to offer some assistance.
-Chad
-Chad
- sdwyer
02 Jan 2020 06:13 #153775
by sdwyer
Hi Chad,
Thanks, I will. Thats a shame... I probably will ask you for some help when the time comes. Thanks!
How does it violate FCC rules? The rules that may be violated for your country may not be an issue here (Australia) or in other places.
Cheers!
Shaun
Cheers!
Shaun
- satiowadahc
03 Jan 2020 00:05 #153841
by satiowadahc
1) its not labelled for any governing body
2) its operating on 433mhz continuously ( FCC says max of 5 seconds, or chirping every 10)
I did a little digging, it seems you can apply for a license if you are at least 70km away from the Murchison Radioastronomy Observatory located at latitude 26° 42’ 15” south, longitude 116° 39’ 32” east; Region 3 (Oceania) has different rules then region 1 (americas) where the FCC wants to own everything
www.legislation.gov.au/Details/F2019C00681
www.acma.gov.au/licences/low-interferenc...s-lipd-class-licence
- AP3
21 Jan 2020 00:30 #155288
by AP3
Replied by AP3 on topic XHC-WHB04B-6 LinuxCNC not working
Wow, That did it !
Time to create page: 0.198 seconds
