XHC-WHB04B-6 LinuxCNC not working
- Uthayne
- Thank you received: 49
28 Sep 2020 18:16 #184193
by Uthayne
Replied by Uthayne on topic XHC-WHB04B-6 LinuxCNC not working
Thanks Romeo, I'm trying this fix out. I reverted back on the hal.cc changes I just made.
If I'm following correctly,
gets changed toandgets commented out?
If so, I just tried it and it has the same jerkiness.
net pdnt.mode.is-manual halui.mode.is-manual whb.halui.mode.is-manualnet pdnt.mode.is-manual whb.halui.mode.is-teleopnet pdnt.mode.teleop whb.halui.mode.teleop halui.mode.teleopIf so, I just tried it and it has the same jerkiness.
- romeofox
28 Sep 2020 18:19 #184194
by romeofox
Replied by romeofox on topic XHC-WHB04B-6 LinuxCNC not working
That's what it was meant to be.
I tested my handwheel with LinuxCNC 2.8 and 2.9. Both worked.
- Uthayne
28 Sep 2020 18:58 - 28 Sep 2020 19:03 #184200
by Uthayne
Would you mind sharing you .hal file? I either keep getting something wrong or it is not working for me.
Edit: changedto add(commented this out on)
and its working now. Strange. I made no other edits.
Full hal file is attached.
Edit: changed
net pdnt.mode.is-manual halui.mode.is-manual whb.halui.mode.is-manualwhb.halui.mode.is-teleopnet pdnt.mode.is-teleop halui.mode.is-teleop #whb.halui.mode.is-teleopand its working now. Strange. I made no other edits.
Last edit: 28 Sep 2020 19:03 by Uthayne.
- Thank you received: 7454
28 Sep 2020 20:58 - 28 Sep 2020 20:59 #184213
Replied by tommylight on topic XHC-WHB04B-6 LinuxCNC not working
I see some angry Austrians coming your way !I solved my handwheel problem with a solution from the german cnc-aus-holz.at forum:
Last edit: 28 Sep 2020 20:59 by tommylight. Reason: typo
