XHC-WHB04B-6 LinuxCNC not working
6 years 2 months ago #179212 by OE5AMP
Hello
I installed LinuxCNC 2.8 with this image " cnc.beaglebrainz.net/cdimage/cnc-19.2.0-...ate-uspace-64bit.iso "
After that I wanted to install the wireless China handwheel according to Talla83's instructions. Formerly with Debian 9 the installation worked with its manual and the handwheel worked perfectly.
Unfortunately that didn't work with Linux Mint anymore.
When compiling I got a lot of errors. So I used the original LinuxCNC folder and recompiled everything.
The handwheel also works, but the machine jerks extremely when moving. With every setting
When I use the buttons in Axis everything works normally.
In the attachment my hal and ini files
Maybe someone can help me.
Thanks in advance
Greetings from Austria
6 years 2 months ago #179271 by diegojulio
Hello: Can you help me to compile the driver in 2.7 with Ubuntu 12.04 Precise? This can be done with this version?
6 years 2 months ago #179309 by anfänger
I also used Tallahassee version and it worked fine. What were the errors during compiling?
6 years 2 months ago #179405 by OE5AMP
Hello
Tomorrow I have to recompile the Talla83 driver again so that I can see what errors occur. I exchanged the folder from the Talla83 with the original folder and then compiled it
6 years 1 month ago #184187 by Uthayne
OE5AMP wrote: The handwheel also works, but the machine jerks extremely when moving. With every setting
I am in the same boat here. Using the built in driver with 2.9, continuous and step mode jogging with the wheel is very jerky on all settings.
The console reports timeout issues while spinning the jog wheel
hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms hal failed to wait for reqested mode. waited 300ms
and watching whb.axis.x.jog-counts shows a lot of missed counts when turning the wheel with any sort of speed.
I was able to get the machinekit/talla83 driver working, but the continuous mode had a fixed jog-scale at 2.0. Step mode worked perfect, but I would wish for the feed rotary to adjust the speed percentage when in continuous mode. The built-in driver adjusts the jog-scale in continuous mode, but has the annoying problem of losing jog-counts.
6 years 1 month ago #184188 by andypugh
Uthayne wrote: I am in the same boat here. Using the built in driver with 2.9, continuous and step mode jogging with the wheel is very jerky on all settings.
Have you tried adjusting the (new) axis.L.jog−accel−fraction pin?
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
Time to create page: 0.237 seconds
