Awesome!
Getting closer got that xhc-hb04 copied in and now when I run it I get some hex displaying when i do things to on the MPG so the connection has succeeded. I did have to "sudo xhc-hb04" to get it to run.
Checked the USB info looks like the right vendor/product info:
Unknown Device
Manufacturer: KTURT.LTD
Speed: 12Mb/s (full)
USB Version: 1.10
Device Class: 00(>ifc )
Device Subclass: 00
Device Protocol: 00
Maximum Default Endpoint Size: 64
Number of Configurations: 1
Vendor Id: 10ce
Product Id: eb93
Revision Number: 0.00
Config Number: 1
Number of Interfaces: 1
Attributes: 80
MaxPower Needed: 100mA
Interface Number: 0
Alternate Number: 0
Class: 03(HID )
Sub Class: 00
Protocol: 00
Number of Endpoints: 1
Endpoint Address: 81
Direction: in
Attribute: 3
Type: Int.
Max Packet Size: 64
Interval: 2ms
Changed this:
loadusr -W xhc-hb04 -I sim-mammoth-rtr.ini -H
to
loadusr -W xhc-hb04 -I xhc-hb04-layout1.ini -H
and put what you said into the xhc-hb04-layout1.ini file.
[XHC-HB04]
BUTTON=01:button-reset
BUTTON=02:button-stop
BUTTON=03:button-start-pause
BUTTON=04:button-feed_up # Macro 1
BUTTON=05:button-feed_down # Macro 2
BUTTON=06:button-spindle_up # Macro 3
BUTTON=07:button-spindle_down # Macro 4
BUTTON=08:button-machine-home # Macro 5
BUTTON=09:button-safe-z #?? # Macro 6
BUTTON=0A:button-work-home # Macro 7
BUTTON=0B:button-spindle # Macro 8
BUTTON=0C:button-fn
BUTTON=0D:button-probe-z # Macro 9
BUTTON=0E:button-continous
BUTTON=0F:button-step
BUTTON=10:button-macro-10
Tried this:
ATTR{idProduct}=="EB93", ATTR{idVendor}=="10ce", MODE="0666", OWNER="root", GROUP="plugdev"
and
SUBSYSTEM=="usb",ATTR{idProduct=="EB93"},ATTR{idVendor=="10CE"}, MODE="666"
in the
/etc/udev/rules.d/99-xhc.rules file
Getting this:
Debug file information:
Note: Using POSIX realtime
libusb: error [_get_usbfs_fd] libusb couldn't open USB device /dev/bus/usb/008/004: Permission denied
libusb: error [_get_usbfs_fd] libusb requires write access to USB device nodes.
./xhc-hb04.hal:91: Pin 'halui.spindle.0.override.increase' does not exist
which leads me to think it's a rules / permission problem?
I did:
sudo chmod o+w /dev/bus/usb/008/004 to see if I can get past that, and am left with:
libusb_claim_interface: Device or resource busy
Commented the next few lines that gave me errors out, and I am at:
./xhc-hb04.hal:35: waitpid failed xhc-hb04 xhc-hb04
./xhc-hb04.hal:35: xhc-hb04 exited without becoming ready
16326
