XHC-WHB04B-6 LinuxCNC not working
7 years 5 days ago #148898 by satiowadahc
I may look into his driver in a few days and see how he has everything set up.
The only other thing I could think of is having the axis selector set to an axis and the step size set to above 0
6 years 11 months ago #150224 by jonch919
I received mine today. Decent build quality for the price.
What version of the driver, and method of install, do you recommend?
There seems to be a few different versions now.
6 years 11 months ago #150232 by JanPan
I used the most straight forward way and build linuxcnc from the git repository including satiowadahc's modified version of the HB04 driver.
This works great (I still have to pimp my .hal, but the driver does what it is supposed to do).
Nevertheless there also is a nice guide from talla83 in the archive on his website talla83.de (the archive is available at talla83.homepage.t-online.de/linuxcnc/XHC-WHB04B-6.zip ).
However, I was not able to work with this version of the driver...
6 years 11 months ago #150244 by jonch919
So you followed the instructions in the youtube video by talla83. But instead of the files he provided, you used files by satiowadahc instead.
Correct?
Where do I find the files you used?
6 years 11 months ago #150257 by satiowadahc
Earlier in this post I have the details.
My source code is here github.com/satiowadahc/linuxcnc/blob/mas...er_comps/xhc-hb04.cc
Which if you grab the linuxcnc source and replace their xhc-hb04 with mine it works like 75% of the commands #148668. Also earlier in this thread is some compiled versions for debian/ubuntu as well #148027
As a note udev/rules.d/ needs a one line file called 99-xhc.rules with:
SUBSYSTEM=="usb",ATTR{idProduct=="EB93"},ATTR{idVendor=="10CE"}, MODE="666"
6 years 11 months ago #150258 by satiowadahc
I've been pulled to a few different projects as of late and haven't been able to get back to finishing the macro commands. but by the sounds of it, not many of my machinists want them, so they might get put to a back burner
Time to create page: 0.303 seconds
