- Thank you received: 52
alkabal wrote: Writing this allow to have something variable but i'm unsure about the real reaction needed for Mpg mode.
I have try to use without success :
halui.feed-override.count-enable (bit, in)
halui.feed-override.counts (s32, in) - counts * scale = FO
halui.feed-override.direct-value (bit, in)
halui.feed-override.scale (float, in)
Is this have more sense ? "In Mpg mode the step speed is in percent of max-velocity"
(if yes the good pin it is halui.max-velocity.value for calc ?)
alkabal wrote: Except that a pendant is mostly a user component, or i'm wrong ?
