Just Getting Started Have Servos Need Direction
- JuniorC
17 May 2019 21:21 #134094
by JuniorC
Just Getting Started Have Servos Need Direction was created by JuniorC
I'm inserted in building a CNC router. I have several Parker GV servo drives and SM motors. I have a cheap breakout board the only does single ended STEP and DIRECTION for the axis. I was told that the drives can be configured for a single ended step and direction signal which there could be issues with noise causing unwanted steps. Or I could configure the drive for a directional signal which would be more stable. I also have an old computer with a parallel port that use to run on windows xp.
Will my drives and motors work with LinuxCNC? If so what brand or type of breakout board is recommended, and is the old computer good enough or do I need a newer computer? I do know that most of the newer computers don't have a parallel port. So is there a card with a parallel port that can be installed in a newer computer that would be compatible with LinuxCNC?
Any info would be great appreciated. There will be possibly more question in the future.
There has been files attached that contains info and specs of the servos and motors I have.
Thanks,
JuniorC
Thanks,
JuniorC
- pl7i92
- Thank you received: 359
18 May 2019 01:51 #134105
by pl7i92
Replied by pl7i92 on topic Just Getting Started Have Servos Need Direction
Hi
First this will work as you expected
IF you invest some money for a 7i77 kombination you will get a REAL mashine acting on -+10V
with all the benefit of the servo Mashine in Speed and Precicion
- JuniorC
18 May 2019 05:56 #134163
by JuniorC
Replied by JuniorC on topic Just Getting Started Have Servos Need Direction
Thanks for your quick response. Is there any certain computer set up? Will this breakout board control a router motor that is driven by a VFD?
Thanks again
Thanks again
- Thank you received: 7506
18 May 2019 17:01 #134220
Replied by tommylight on topic Just Getting Started Have Servos Need Direction
7i77 can control 5 axis plus a spindle, all with +-10V and all with differential or single ended encoders with or without index signals, has 32 inputs and 16 outputs, and it needs one of the following : a 5i25 for PCI, a 6i25 for PCI expres or a 7i92 for Ethernet control .Thanks for your quick response. Is there any certain computer set up? Will this breakout board control a router motor that is driven by a VFD?
Thanks again
- Hakan
- Thank you received: 497
19 May 2019 01:10 #134237
by Hakan
Replied by Hakan on topic Just Getting Started Have Servos Need Direction
Regarding the computer, there is always that thing with how precise in time it can be. Jitter. You can install a live linuxcnc linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html and measure the jitter. For parallel ports one wants jitter to be below som value, don't remember which. With a mesa card the jitter requirement is reduced to the point that almost any PC works.
About the 7i77 and analog interface - is it really the best interface? The drive is digital, isn't it better with a digital interface then?
- pl7i92
19 May 2019 01:25 #134240
by pl7i92
you can also go ethernet with the 7i92 + 7i77 combiation instat of using pci
digital woudt be great for him is this suppurted by linuxcnc
- Hakan
19 May 2019 02:09 #134245
by Hakan
The drive seems to be configurable +-10V analog, Step/Direction and CW/CCW. I think of the last two as digital interface. Not very advanced like more high-end, but still. So, is +-10V better than Step/Dir or CW/CCW? I feel it might cause a flame war, but that is not the intention.
- JuniorC
19 May 2019 05:33 #134258
by JuniorC
Thanks to all of the replies. I'm looking and shopping around for a 7i77. This seems to be the way to go. As far as a card I'm not sure. Have to see what type of card my old desktop supports. If it's not too hard to configure for the 7i92 card. I have an extra laptop that is fairly new.
I'm still educating myself on the drive and how to get everything to communicate. As far as analog and digital not sure if this is going to be an issue for what I'm wanting to do.
With that being said. I know very little about controls but I'm a self educated on several things. A little about myself. Just an old country boy that went to a vocational school for tool and die. Worked in machine shops for several years which transitioned to maintenance and then an automation tech. I have CNC programming experience and some PLC programming. Hope I didn't babble too much. Just thought I would let you all know my skill set. So this is why you may get asked some silly questions.
Thanks again.
Thanks again.
- Thank you received: 5337
19 May 2019 06:39 #134262
Replied by PCW on topic Just Getting Started Have Servos Need Direction
If this is your first CNC project and experience with LinuxCNC, you might be
better off using the drives step/direction interface, as its much easier to get
basic motion and easier to troubleshoot than servo system with feedback to LinuxCNC.
You should be able to run the drive with just a parallel port
on a junk PC so probably don't need to buy any hardware to get started.
The following user(s) said Thank You: andypugh
- pl7i92
19 May 2019 09:14 #134275
by pl7i92
you may need a small breakout board 8USD
as i use to test mashining
nice easy and dirty
but it also works in big scale
nice easy and dirty
Time to create page: 1.358 seconds
