Help with Mesa 7i76E, Cannot get it working.
- itstheburns327
- bevins
- Thank you received: 338
- itstheburns327
- itstheburns327
- Thank you received: 7468
- bevins
255.255.255.0, no gateway
That's a class C mask.
- Thank you received: 5321
I do have a question though, when using the Mesa card, it has step and direction plus and step and direction minus. My gecko drivers only have step direction and common. Do I just common together step and direction minus? As for limit switches and home switches, I think I have that part figured out.
For single ended drives like the Gecko, you use the appropriate output pin
(usually - Step/-Dir if the drive common is +5V or +Step/+Dir if the drive common is 0V)
The unused outputs on the 7I76E _must_ be left unconnected
- bevins
For 10.10.10.n that usually is 255.0.0.0, but in this case it works as is.
And you should also set the gateway and the DNS at 10.10.10.1
- itstheburns327
