Help with Mesa 7i76E, Cannot get it working.
29 Sep 2019 23:24 #146641 by PCW
Can you post your hal and in files?
Did you increase the default step times to say 5000 ns?
29 Sep 2019 23:36 #146646 by itstheburns327
Replied by itstheburns327 on topic Help with Mesa 7i76E, Cannot get it working.
Let me know if there are other files you need.
30 Sep 2019 00:11 #146651 by PCW
OK, I would not expect those timings to work, I would start with at least 5000 ns for steptime
30 Sep 2019 00:17 #146652 by itstheburns327
No change
30 Sep 2019 00:24 #146653 by itstheburns327
Let me ask you this. What is the absolute minimum that needs to be connected to this Mesa card for it to control a stepper? I only have a stepper drive connected and one stepper. Do I need to have a limit switch configured and connected? I'm looking for something simple just to make this stupid thing work. I don't have a 24 volt power supply, only a 50 volt unregulated power supply, 12 and 5 volt power supplies. The only power supply connected to the Mesa card is the 5 volt on the P3 connector. The Mesa manual for this card doesn't say anything about any minimum power requirements so maybe that's my issue?
30 Sep 2019 00:46 #146655 by bevins
You dont have field power connected?
30 Sep 2019 01:10 - 30 Sep 2019 01:12 #146659 by itstheburns327
I tried with with and without field power. The mesa manual says it can power the entire card from the field power input but its not. I still need 5v at p3. As i've said, the mesa manual doesn't specify minimum required power inputs, only that it can power the whole board from field power or p3 for the logic. Is p3 enough to run the rest of the board?
Last edit: 30 Sep 2019 01:12 by itstheburns327.
30 Sep 2019 01:24 #146661 by PCW
1. You dont need field power to run the step/dir outputs (so 5V at P3 should work)
2. You can run the entire card from 12/24VDC if you wish by powering both the
field power (TB1) and the unregulated logic power (TB3 pins 21 through 24)
from 12/24V ( and no connections to P3 )
30 Sep 2019 01:41 #146663 by itstheburns327
I think I'm going to have to abandon LinuxCNC and the Mesa card. I've spent way too much time on this and its not working for whatever stupid reason. It seems that everything is connected correctly and I've tried multiple combinations based on other user configs. I had high hopes of this Mesa card with all of the inputs and outputs, reasonable cost with powerful features and LinuxCNC. I've never had much luck working with any flavor of linux and this experience just adds to that. I have to say, despite the unpleasant hardware experience, the forum experience with you guys has been A++. I want to extend a full thank you to everyone for your time, information and patience.
30 Sep 2019 02:08 #146665 by PCW
Before you give up, can you do a very basic test?
Start LinuxCNC and jog X in both directions while measuring the DIR0 outputs
(from +DIR0 to -DIR0)
This should give you about +5v in one direction and about -5V in the other direction
Also have you gotten any error messages from LinuxCNC?
