Mesa Flash - Mesa 7i94.
6 years 11 months ago #150219 by Moreira
Replied by Moreira on topic Mesa Flash - Mesa 7i94.
Hello PCW,
Yes, I've done that. Thank you!
6 years 11 months ago #150220 by tommylight
Replied by tommylight on topic Mesa Flash - Mesa 7i94.
Can you please tell us what are you trying to achieve as the end result, it seems you keep trying to do things you really do not need to.
On the first screen you are using a config for a parallel port and your PC does not have one, at least not at the address it is looking for (0x378).
6 years 11 months ago - 6 years 11 months ago #150222 by Moreira
Hello,
At this point I want to create a configuration (Hal.file and Ini.file) that I can edit and adapt to my application.
However, I'm not sure if the re-built LinuxCNC 2.8 will work witth Mesa 7i94. So, I just selected a sample configuration to test it. It crashes when I select this : "Sample Configurations\by_interface\parport\etch-servo\etch"
However, this does not happen when I use the LinuxCNC 2.7, which is currently installed.
Last edit: 6 years 11 months ago by Moreira.
6 years 11 months ago #150228 by tommylight
What is 7i94 supposed to do? Stepgens? GPIO? Encoders? PWM? SSI, Smart Serial ?
6 years 11 months ago - 6 years 11 months ago #150230 by Moreira
Smart Serial and GPIO (for home switches).
The current firmware is the 7194ss_5abobd.bit
6 years 11 months ago #150234 by PCW
Replied by PCW on topic Mesa Flash - Mesa 7i94.
The first step would be to get a working 7I94 hal file, you will not get far with hal files for other hardware. I think I have a test config (for step-dir) you can try but I have to dig it up
Also here is the latest snapshot of Mesa HM2 changes:
freeby.mesanet.com/newmesa.zip
Note that this should be unzipped into the yourlinuxcnc-dev/src/hal/drivers/mesa-hm2 directory and the Makefile moved to yourlinuxcnc-dev/src
Time to create page: 0.227 seconds
