Mesa Flash - Mesa 7i94.
6 years 11 months ago #150307 by andypugh
Replied by andypugh on topic Mesa Flash - Mesa 7i94.
My suggested procedure still has some things going for it, as it takes a lot of surrounding stuff out of the equation.
But it does need to be "hostmot2".
The following user(s) said Thank You: Moreira
6 years 11 months ago #150320 by PCW
Replied by PCW on topic Mesa Flash - Mesa 7i94.
Yes, halcmd is great way to debug hardware and software setups, list pins and parameters etc without the need for a hal/ini file
Its also better for live tweaking pins and parameters than the GUIs "show" interface because it has command completion and you inherit command history and line editing from the terminal interface
6 years 11 months ago - 6 years 11 months ago #150352 by Moreira
Replied by Moreira on topic Mesa Flash - Mesa 7i94.
Hi Andy,
I've implemented your suggested procedure. It recognises the board and displays the pins.
Thank you!
Last edit: 6 years 11 months ago by Moreira.
6 years 11 months ago #150375 by andypugh
Another tip, you can use the command line to connect to a live system:
halcmd -kf
That allows you link and unlink pins, load and unload HAL components, start halmeters (loadusr halmeter pin motion.program-line for example), start the halscope (loadusr halscope) etc etc.
Anything you can do in a HAL file you can do live at the command line.
6 years 11 months ago #150377 by Moreira
This is great! Thank you!
6 years 4 months ago #172376 by Henk
Replied by Henk on topic Mesa Flash - Mesa 7i94.
Hi. Is the 7i94 supported by the standard 2.7.15 distribution?
Henk
Time to create page: 0.413 seconds
