Hi PCW,
I've re-built the linuxcnc (
github.com/KurtJacobson/RF45-CNC/wiki/Bu...LinuxCNC-From-Source
) after replacing the hm2_eth.c and pins.c files in the directory: linuxcnc-dev/src/hal/drivers/mesa-hostmot2/
When I tried to compile (make) the 2.7 branch I had multiple undeclared errors generated by the pins.c file.
So, I tried the 2.8 branch and It also generated errors but they were all related to the undeclared definition "HHM2_GTAG_INMIX". Then, I opened the pins.c file and commented the lines of code which use this definition and it worked! Please find attached the modified pins.c file.
Then, after launching the linux cnc from the terminal I came across with the window "Confirm automatic update". It says I should update linux cnc.
I ignored this and I was getting errors: "the linux cnc was shutting down and cleaning up"
What linux CNC version should I be using with mesa i794?
Should I update linux cnc?
Best Regards,
Laura
