Mesa Flash - Mesa 7i94.
6 years 11 months ago - 6 years 11 months ago #150287 by Moreira
Replied by Moreira on topic Mesa Flash - Mesa 7i94.
Hi PCW,
what is the linuxcnc branch?
I've replaced the files in the mesa-hostmot2 directory of the linuxcnc 2.8 and it compiled successfully.
However, when I try to open a working configuration it complains about an undefined symbol: hm2_xy2mod_force_write.
Last edit: 6 years 11 months ago by Moreira.
6 years 11 months ago #150293 by andypugh
Replied by andypugh on topic Mesa Flash - Mesa 7i94.
Perhaps it is worth trying to keep things minimal at this point.
If you open a terminal window and type:
halrun loadrt hostmot2 loadrt hm2_eth board_ip=10.10.10.1
(You may need to change that IP address, depending on your config)
Do you see any errors?
If not, then you can carry on with commands like
show pin
to get a list of all the HAL pins that will be valid in your config.
exit
to leave the halcmd prompt.
6 years 11 months ago #150298 by Moreira
Hello,
I've just done it and it didn't work!
6 years 11 months ago #150299 by PCW
Replied by PCW on topic Mesa Flash - Mesa 7i94.
That error means that you did not move the included Makefile that includes the xy2mod object to the src directory
hostmot2-objs := \
hal/drivers/mesa-hostmot2/hostmot2.o \
hal/drivers/mesa-hostmot2/ioport.o \
hal/drivers/mesa-hostmot2/encoder.o \
hal/drivers/mesa-hostmot2/abs_encoder.o\
hal/drivers/mesa-hostmot2/resolver.o \
hal/drivers/mesa-hostmot2/pwmgen.o \
hal/drivers/mesa-hostmot2/inmux.o \
hal/drivers/mesa-hostmot2/xy2mod.o \ <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
The following user(s) said Thank You: Moreira
6 years 11 months ago #150300 by PCW
its hostmot2 not hotmot2
6 years 11 months ago #150302 by Moreira
PCW you were right!
I forgot to copy the makefile into the source directory!
It's working now!! I can load the linux CNC and It recognises the board 7i94.
Thanks a lot!!
Time to create page: 0.546 seconds
