- Thank you received: 8
Problem with a MESA 7i76
- Ameone
6 years 10 months ago #152752
by Ameone
Replied by Ameone on topic Problem with a MESA 7i76
I currently don't have an oscilloscope. Is there any other way to check these outputs?
- Thank you received: 5334
6 years 10 months ago #152753
Replied by PCW on topic Problem with a MESA 7i76
Measure the + and - outputs to ground with a voltmeter
- Ameone
6 years 10 months ago #152755
by Ameone
Ok they are all constant to 5V.
6 years 10 months ago #152756
Also you can check the outputs by verifying that they change state when LinuxCNC starts.
The + outputs should all be in the high state and - outputs all in a low state when LinuxCNC
is not running. When LinuxCNC is running (and idle) all of the + step outputs should be low
and all the - step outputs should be high.
6 years 10 months ago #152757
If the + and - outputs are both at 5V relative to ground, then its likely the 7I76 has been damaged (or you are not reading the outputs correctly)
- Ameone
6 years 10 months ago #152838
by Ameone
Hi everyone sorry for the delay, we have checked what you asked: for the TB2 the + and - outputs are all at 5V constant, so probably the board was damaged. Thanks again for all the fast feedback.
Time to create page: 0.291 seconds
