Problem with a MESA 7i76
6 years 10 months ago #152738 by Ameone
Replied by Ameone on topic Problem with a MESA 7i76
Ok thanks for the quick feedback. I've tried but nothing happens! The oscilloscope we had in the lab is not working so I cannot test the pins.
6 years 10 months ago - 6 years 10 months ago #152739 by PCW
Replied by PCW on topic Problem with a MESA 7i76
I would try making the step length longer than 1 usec (1000 ns)
1 usec will fail on 95% of step drives
5 usec is usually a better starting place
Last edit: 6 years 10 months ago by PCW.
6 years 10 months ago #152741 by Ameone
I've also tried your solution but still no results.
6 years 10 months ago - 6 years 10 months ago #152744 by PCW
No outputs from stepgens 0..3 could also be the result of a damaged 7I76
(the first 4 stepgen outputs come from 2 chips, 1 for the + step/dir outputs and 1 for the - step/dir outputs)
Do the direction outputs work? (check + and -)
what are the output voltages?
6 years 10 months ago #152750 by Ameone
I've checked the dir outputs: for the first four motors the outputs don't switch (always at 5V), while the dir works for the fifth motor (switch correctly from 5V to 0V and viceversa).
The 7i76 is new, I really hope it's not damaged!
6 years 10 months ago #152751 by PCW
did you check the + and - outputs?
Time to create page: 0.159 seconds
