Problem with a MESA 7i76
6 years 7 months ago #159027 by RobTC
Replied by RobTC on topic Problem with a MESA 7i76
Appreciate all your rapid responses! Once I got going I figured I may as well do them all, though I doubt half of them matter to this issue. All individual resistors check out within a 5% tolerance of: RN1,4,18,25,26 @ 27R, RN11,13,20 @ 138R, RN10,12,19 @ 145R, RN3 @ 47R.
I guess it's the buffers. Not sure how, though, makes no sense. Is it feasible to test the buffers if I provide 5V bench power to TB3 and move the jumper? I do have a parallel terminal breakout lying around doing nothing if it helps to go in through P1 and the datasheet appears pretty straightforward.
6 years 7 months ago #159039 by PCW
Replied by PCW on topic Problem with a MESA 7i76
Yes they are just basic non-inverting buffers (74ACT541 on + pins) and
inverting buffers (74ACT540 on - pins) connecting between the DB25 and
the 27 Ohm resistor networks
2 years 4 months ago #303934 by disneysw
Replied by disneysw on topic Problem with a MESA 7i76
Sorry to dig up an old thread but I have fried a 7I76 board due to connecting the end stop plug into the spindle connector and shoving 24V where it was never supposed to go!
Mine is a rev C board and PTC4 is badly scorched but still seems to be working. CR17 went short circuit and was burnt to a crisp which in some ways may have been a saving grace.
The FPGA is working and the voltage rails look good but the stepper buffers seem to be damaged.
I know I need to order SSOP versions of the 74ACT541 and 74ACT540 but what values are the PPTC and CR17? What else may have gone?
Finally is the schematic for the 7i76 available?
2 years 4 months ago #303943 by PCW
You must mean 7I76E if you have CR17
CR17 is a SMBJ5V0 (SMB package)
Its job is to prevent overvoltages on the the
7I76Es 5V rail.
If PTC4 was fried that sounds like you accidentally
connected 24V to the 5V outputs on TB3. PTC4 is a
1206 2A PTC MF-NSMF200-2
Most likely hidden damage would be to 5V parts
U10 (serial), U12 (step/dir 0..3), U15 (encoder) ,
U19 (step/dir 0 ..3),  and U24 (step/dir 4)
Also if 24V got routed to step/dir outputs, the 27 Ohm resistor
networks near the step/dir outputs may have been damaged
(check with ohmmeter, damage =  high resistance/open)
2 years 4 months ago #303954 by disneysw
Your right it is a 7i76E.
The resistor network is OK but the markings on IC's are very faded so what should I be ordering?
(I am in the UK and going to have to pay a minimum order handling charge to Farnell so I may as well order them all at the same time).
And thank you for your help!
2 years 4 months ago #303971 by PCW
Yes, laser marked parts are hard to read unless you have the light just right...
U10 26LS31 (SOIC16)
U12 74ACT540 (TSSOP 20)
U15 26LS32A (SOIC16)
U19 74ACT541 (TSSOP 20)
U24 74ACT04 (SOIC 14)
Time to create page: 0.218 seconds
