LinuxCNC embedded into automation machine
- hhscott
- Thank you received: 15
(Debian 7) This gives the best real-time performance and is generally a better choice for software stepping using a parallel port
(Debian 9) It should probably be the first version tried even if using a parallel port. This is compatible with all Mesa and Pico interface boards
From the language it leads me to think that 7 is better for software and 9 "Might" work. If you are using an external card (Mesa) then 9 is definitely the way to go.
Since I am using the parallel port for software stepping I was wanting clarity that 9 is stable enough. I installed it (9) and I am testing now.
Thanks,
HH
- Thank you received: 1479
- hhscott
The right mother board can handle it.
I thought I had the correct board: ASRock Q1900B-ITX. I am using 8GB of memory with a 500GB SSD. My latency test numbers are not what I was expecting:
Servo thread 42152
Base thread 161012
Multiple test and multiple reboots yield these same basic results. Nothing other than the browser running.
In my bios:
Advanced --> CPU Config --> Disable everything beside "No-Execute Memory Protection"
Advanced --> Super IO --> Device Mode --> Bi-Directional
IO=378 with every IRQ
Any thoughts?
HH
- Thank you received: 5330
- hhscott
Did you disable all power management including any cstates above C1?
No. Not exactly sure where to go in the Bios for power management?
- hhscott
Which release of 9 should I have downloaded from the download page? There seem to be multiple options for 9.
HH
UPDATE 1:
I downloaded another Debian 9 linuxCNC image and ran it as live. The latency test were the same. Could I have bad hardware on the board?
UPDATE 2
Edited GRUB with Isolcpus 1,2,3. This resulted in a massive reduction in the latency, now running at < 10000. Other function have slowed down but as long as LinuxCNC runs stable at these speeds all is well.
- satiowadahc
- Thank you received: 12
import linuxcnc, hal
#load the libraries
stat = linuxcnc.stat()
com = linuxcnc.command()
halcomp = hal.component("component1")
# initialize some pins if you wish
# set the comp ready
halcomp.ready()
stat.poll()
# should home before issue commands
com.home(0) # x
com.home(1) # Y
com.home(2) # Z
com.command.mdi("G0 X1Y1")
We use the hal and linuxcnc in a lot of python scripts. The biggest issue we find is homing the machine, we cheat the headless idea and home through a GUI.
You can use a conventional INI with hioming sequence definitions etc.
But set DISPLAY = halui
Then you can home from the Python interface, or by toggling halui homing pins.
- hhscott
Help me to understand HAL to control LinuxCNC? I am using the python module and it seems to be working perfectly. I can poll for the current state, reset the E-stop, turn on the power button, issue homing commands, load the desired G Code and then run the machine all without issue so far. (Desktop simulation)
Is HAL incorporated into the python/linuxCNC module or is this a separate environment? Searching through the python module docs I see no reference to HAL. I am curious BC I want to make sure that I am utilizing the best practices in this application, it will run in an industrial setting at least 8 hours per day. Again, complete newbie here with LinuxCNC.
Thanks,
HH
HALUI offers a set of similar inputs inputs and outputs that can be used in parallel to the Python module. For example to wire a physical hardware IO to an axis-homing command (probably not something you would want, but thats one example)
