LinuxCNC embedded into automation machine
- hhscott
- Thank you received: 15
16 Mar 2020 10:20 #160405
by hhscott
Replied by hhscott on topic LinuxCNC embedded into automation machine
Thanks for the reply. That clears things up a bit.
Moving beyond the parallel port (my first intention was to run via parallel) I have ordered the Mesa 7i76e BC my application will require more field GPIO than whats available on the native PP.
I am running Debian 9 (From the LinuxCNC downloads) with LinuxCNC 2.7.15. Will this version support the 7i76e and does it have the installation wizards for that card? If I have to upgrade the LinuxCNC version can I keep the general OS installation, I have made many tweaks to the OS for my app and would prefer to just upgrade LinuxCNC and leave the OS alone.
HH
HH
- Thank you received: 4652
16 Mar 2020 11:55 #160414
That version of LinuxCNC will work with the 7i76E. The bigger question is whether you have a compatible kernel.
What does uname -a say?
Replied by andypugh on topic LinuxCNC embedded into automation machine
- Thank you received: 7468
16 Mar 2020 11:59 #160415
Replied by tommylight on topic LinuxCNC embedded into automation machine
Debian 9 should work with Mesa ethernet, if it is the Linuxcnc version of it.
Check in terminal
uname -a
should have preempt rt somewhere.
Do not know about wizards, i rarely use them.
Check in terminal
uname -a
- hhscott
16 Mar 2020 12:35 #160419
by hhscott
Input:
uname -a
Output:
Linux angio 4.9.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64 GNU/Linux
Wil this work?
HH
uname -a
Output:
Wil this work?
HH
16 Mar 2020 12:53 #160421
Yes.
Time to create page: 0.184 seconds
