Getting arc pierces on lead in on inside cuts
- bbsr_5a
- Thank you received: 106
you then can adjust parameters for the day
- Thank you received: 7487
- TexasCNC
One is in the display section, one should be in TRAJ section if i remember correctly, and for each axis there are two entries, if using 2.8 or 2.9 version of Linuxcnc.
- TexasCNC
- TexasCNC
Also on the Axis panel on the bottom where it reads the Arc voltage in real time while cutting is that suppose to be reading the voltage cause mine is at 0 the entire time.
- phillc54
- Thank you received: 2100
Can you post your ini and hal filesI still can get the max velocity to change or get faster is there somewhere else I need to edit?
I think you are using a Proma, so no it won't show the voltage. I should hide that display for Mode 2...Also on the Axis panel on the bottom where it reads the Arc voltage in real time while cutting is that suppose to be reading the voltage cause mine is at 0 the entire time.
- TexasCNC
- TexasCNC
- phillc54
Can you zip the complete config?
