I Need help for 4 axis cnc
6 years 7 months ago #161636
by Endless
Please watch video... with this machine I want to make holes on the 4 sides of the wooden panel. I don't want to simulate. just turn 90 - 180 - 270 - 360 degree enough for me
Replied by Endless on topic I Need help for 4 axis cnc
6 years 7 months ago #161644
Replied by tommylight on topic I Need help for 4 axis cnc
bilmem turkce abey !
That explains the workings nicely, should not be hard to do, i am sure we have done much more complicated stuff with Linuxcnc.
6 years 7 months ago #161765
Replied by cmorley on topic I Need help for 4 axis cnc
To my thinking it depends how you need to use the drill.
One way would be that the drill is completely independently controlled in the z axis -basically meaning you have two z axis. (maybe z and w?)
The second is that the drill when used is always use fully extended and you use the main z axis to set it's drill height.
You position the drill (extend / rotate) using HAL and then it's just tool offsets.
Andy is usually good at thinking these things through in smart ways.
Chris
Chris
6 years 7 months ago #161846
Replied by andypugh on topic I Need help for 4 axis cnc
Custom kinematics and drilling in the W axis might be a way to go.
Though it would be possible to use coordinate-system rotation so that the drill moves are straight X (or Y, if you prefer)
Imagine drilling a hole at 45 degrees, and assuming that the rotary axis is C.
G0 C45
G10 L2 R45 (rotate the XY axes about Z)
G1 F20 X100 (drill a hole at 45 degrees)
G0 C45
6 years 6 months ago #162618
by Endless
I have no information about what you say. because this is my first cnc machine. Will a post process be required for the CAM program? I don't even know this... please someone guide me. I would be very happy if he tells me what to do step by step...
I do not want the machine to work simultaneously. just turn the axis 90-180-270-360 in the video and drill the hole
Please help
Please help
6 years 6 months ago #162619
by Endless
Thanks for answer but ı dont know HAL
Time to create page: 0.061 seconds
