I Need help for 4 axis cnc
6 years 7 months ago #161463
by Endless
Replied by Endless on topic I Need help for 4 axis cnc
thank you for your interest. Will it be necessary to write a post processor according to the CAM program to be used? I do not know how to do this, I do not know how
6 years 7 months ago #161467
Replied by cmorley on topic I Need help for 4 axis cnc
Depends on the cam program. Some have linuxcnc or Mach post processors and a general Fanuk post processor should get you close for plain gcode programs.
6 years 7 months ago #161468
by Endless
Did you look at the pictures in my first message?
my machine is not a standard machine
6 years 7 months ago #161553
Ahh yes - the second head is a little non standard
What does it do?
What does it do?
6 years 7 months ago #161563
Replied by tommylight on topic I Need help for 4 axis cnc
As far as i can tell from that drawings, it is a dual drill setup with 90 degree rotation.
6 years 7 months ago #161592
by bbsr_5a
Replied by bbsr_5a on topic I Need help for 4 axis cnc
Hi
solidcan has a 4th axis post for Fanuc11m that will shure fit your need
if not licenced you simply can use a Free Autodesk product for small busines
the 4th axis is only a setup
i mainly use them as a B axis as the Y is then the main axis and the machine dont move in X Gantry
its basicly a lathe type machine 3Axis YZB with X takeng the center pont wherever 4th axis is located at the large Table
Time to create page: 0.060 seconds
