- Thank you received: 106
I Need help for 4 axis cnc
6 years 6 months ago #162646
by bbsr_5a
Replied by bbsr_5a on topic I Need help for 4 axis cnc
all you need to know in first hand is that it will work with linuxcnc so you can start to build
the postprocess is your Word/Notpad or as you are on linux GEDIT to change your axis 0-90-180-270 by adding the command
your CAM and Post works flat out
the 2 Tools will have diferent coordinate system G54 G55 they arte on so the offset is non problem
the Z is for the First tool
the w for the Second
if it is only this 2 tools not a 11head machine it is far easyser then you think
6 years 6 months ago #162666
Replied by rodw on topic I Need help for 4 axis cnc
you will by the time you build this machineEndless wrote: Thanks for answer but ı dont know HAL
Time to create page: 0.045 seconds
