Z axis
6 years 5 months ago #168084 by motal2004
Replied by motal2004 on topic Z axis
I also get the following when I start my configuration
<commandline>:0: pin or parameter 'plasmac_run.cut-type' not found
File "./plasmac_gcode.py", line 55, in <module>
cutType = int(Popen('halcmd getp plasmac_run.cut-type', stdout = PIPE, shell = True).communicate()[0])
ValueError: invalid literal for int() with base 10:
6 years 5 months ago - 6 years 5 months ago #168097 by phillc54
Replied by phillc54 on topic Z axis
motal2004 wrote: I also get the following when I start my configuration
[strike]This is telling you that you haven't yet saved this parameter (you don't even need it unles you have Powermax comms), you can stop it by opening the run panel and pressing Save
[/strike]
Sorry, I read that wrong...
This shouldn't happen, there is a bug in my error checking, I will fix this. It is possible that this is causing some issues because normally when you get an error like this the program doesn't completely load.
Last edit: 6 years 5 months ago by phillc54.
6 years 5 months ago #168098 by phillc54
I totally misread your error message and went off on the wrong tack. :blush:
For some reason Gmoccapy is trying to load "imperial_squares.ngc", you need to edit "az_cnc_plasma.pref" so:
open_file = /home/azcnc/linuxcnc/nc_files/examples/plasmac/imperial_squares.ngc
just reads:
open_file =
You cannot open files on program load with PlasmaC as all the required HAL pins are not yet established.
The next thing you need to change is Arc OK Low, a starting point for that is around half of your expected cut volts. You can tune it later if you wish.
6 years 5 months ago #168151 by motal2004
[quote
The next thing you need to change is Arc OK Low, a starting point for that is around half of your expected cut volts. You can tune it later if you wish.[/quote]
my current arc ok low is set to 0 would that not be achieve the same as of half of the expected cut volts as you suggested?
6 years 5 months ago #168155 by tommylight
Replied by tommylight on topic Z axis
That is why the ARCOK is going on and off all the time, it should be set at something like 60 to 80V.
6 years 5 months ago #168204 by phillc54
motal2004 wrote: my current arc ok low is set to 0 would that not be achieve the same as of half of the expected cut volts as you suggested?
It will behave like Tom said. The slightest bit of noise would give an Arc OK then if the noise disappears then you will get a lost arc.
Time to create page: 0.372 seconds
