Hi again.
I’m finishing up my basic configuration so I can start on the PlasmaC .I’m stuck on the z axis specifically with the limits setting.
I have all other axis calibrated, home switch switch work along with the offset. I hit the home all button they all work but the z axis.
I attached a picture of my z axis for reference. I’m following the plasmac users guild, I’m in section 4.4 My Questions are ;
I set my the switch inputs for all axis to “home”, pnnconf wizard, X YY’ are working this way. Should I keep z axis the same or should I select a limit/home shared.
In the picture a tab on the left side is the proximity sensor marker. Is this suppose to be my home? Travel up, towards stepper motor is 1.5 inch max and travel to slats is about 3.85 inches
