Z axis
6 years 4 months ago #171063 by phillc54
Replied by phillc54 on topic Z axis
I cannot see anything obvious, the three setp lines in connections.hal have a couple of tabs in front but I don't think thart would cause any issues.
Strange that it gives lost arc error on the second cut.
Have you done a few probe tests to confirm it ends up at the correct height.
6 years 4 months ago #171064 by phillc54
This connections.hal will debounce the Arc OK signal if you want to give it a try.
You will need to restart LinuxCNC after you copy it to your config folder.
If this doesn't help you may need to do a few Halscope plots for us.
6 years 4 months ago #171066 by motal2004
Replied by motal2004 on topic Z axis
in mode 1. I notice there is now pause for arc to establish . program just starts and the plasma cut does not go all the way through with in the 10mm of start point . I will try the debounce file tomorrow.
thank you i will update.
also can you go over on how to get these Halscope plots
6 years 4 months ago #171067 by phillc54
motal2004 wrote: in mode 1. I notice there is now pause for arc to establish . program just starts and the plasma cut does not go all the way through with in the 10mm of start point .
Increase the Pierce Delay.
There is a good tutorial here. linuxcnc.org/docs/2.8/html/hal/tutorial....ec:tutorial-halscope
6 years 4 months ago #171068 by phillc54
Is you OK to move signal wired directly to the 7i96 or through a solid state or mechanical relay.
Time to create page: 0.234 seconds
