Z axis
09 Jun 2020 13:54 #170836 by motal2004
Replied by motal2004 on topic Z axis
Here’s the link again.
drive.google.com/drive/folders/1kC6XCTTn...hyT01I3dVa-FV2GHv8h-
Ya I’m going to make those connections tonight.
My Follow up Question to that is . My plasma machine has to outputs for “ok to move” do connect both those outputs to input in my Mesa 7i96 board?
09 Jun 2020 15:53 #170842 by bbsr_5a
Replied by bbsr_5a on topic Z axis
you can add this together as one
THCok signal and PlasmaOK signal to spindle-at-speed
loadrt and2 count=1
addf and2.0  servo-thread
net thcok    and2.0.in0  <=  hm2_7i92.0.gpio.xxx.in
net plasmaok    and2.0.in1  <=  hm2_7i92.0.gpio.xxx.in
net readytomove  and2.0.out => motion.spindle-at-speed
09 Jun 2020 16:51 #170846 by motal2004
loadrt and2 count=1
would i at this in the connection hal file?
09 Jun 2020 23:05 #170887 by phillc54
Replied by phillc54 on topic Z axis
If you are using PlasmaC then the OK To Move would connect to your 7i96, something like:
net plasmac:arc-ok-in hm2_7i96.0.gpio.000.in => plasmac.arc-ok-in
in you <machine_name>_connections.hal and you would change the mode in the ini file to MODE = 1
10 Jun 2020 13:38 #170960 by motal2004
I switch to mode 1 and I have my un-comment the
net plasmac:arc-ok-in hm2_7i96.0.gpio.005.in => plasmac.arc-ok-in in my hal file.
I home my machine, probe test, and load up file and hit run program. machine moved to position, torch fires up, and moved 2 inches in the y direction and program stops , I get "e-stop error" and "joint 3 error" this in gmoccapy. I will try axis and will take videos of both and post them tonight.
11 Jun 2020 01:17 #171039 by motal2004
Build configurations from scratch in axis and gmocappy I get the same results .
PlasmaC mode 1
Ark ok wired in.
So below is a link to the video files I save . 1 video started test cut and it stops after first hole is cut out.
Second video , name arc ok disconnected “ is where I disconnected ark ok pin and torch cycles on 3 time before I get no arc detected error, my way of testing that I’m getting a signal to the correct pin location.
Video 3 is shows another attempt at cutting and with arc ok connected and what is show on the screen.
What else can i do?
Videos in file are not in order I label them should be easy to identify
11 Jun 2020 01:25 #171044 by phillc54
Can you zip your complete config and post it.
11 Jun 2020 01:33 #171048 by motal2004
Here they are.
I also attached the ngc file I've been testing with
  • Moderator
  • Moderator
11 Jun 2020 01:34 #171051 by tommylight
Replied by tommylight on topic Z axis
Video with no arc ok connected >>> the torch is to high
Video with arc ok >>>>you are getting "valid arc lost" while probing, that should not happen under any circumstances, so you should check your wiring or something left in hal that is causing ARCOK signal to go true.
11 Jun 2020 01:48 #171061 by motal2004
Wiring as far relay connection for torch on off or like every single wire in the complete system. I’m getting the same error in mode 1 or 0 . Little lost here
Time to create page: 0.286 seconds
