Z axis
6 years 5 months ago #168805 by motal2004
Replied by motal2004 on topic Z axis
rodw wrote: I thought you were having the weekend off ! :huh:
I am, I just asked those questions last night Before I promised my wife I would not touch my table for 72 hrs. She witnessed my little temper tantrum LOL.
6 years 5 months ago #168851 by jay1st
Replied by jay1st on topic Z axis
stupid question, but what plasma generator are you using ?
6 years 5 months ago #168879 by motal2004
jay1st wrote: stupid question, but what plasma generator are you using ?
Primeweld Cut 60
primeweld.com/products/cut-60-220v-110v-60-amp-plasma-cutter
It’s a nice machine When I use the hand torch,
The following user(s) said Thank You: jay1st
6 years 5 months ago - 6 years 5 months ago #168940 by jay1st
I had a look and in some places they say it's a blow back and on others they say it's pilot arc.
So, if it's either one there is ground wire feeding the cup and the THC
The THC is reading the voltage between ground and the active tip, normally grond is the work piece, but with a pilot arc / blowback the cup of the nozzle is grounded too, that means what ever distance the torch is from the work piece the voltage never changes.
Have a look at this thread
forum.linuxcnc.org/plasma-laser/39071-ho...ith-pilot-arc-plasma
To make sure i was on track, i disonnected the ground wire going to the torch once the plasma fires correctly. And then the THCAD started working.
Last edit: 6 years 5 months ago by jay1st.
6 years 5 months ago - 6 years 5 months ago #168999 by motal2004
Before going down your suggested route,
my understanding from the linuxcnc doc, both HF and Blowback start plasma machine have a pilot arc.
I was told by the rep, before purchasing, that the cut60 is not a HF type of machine. now i get my current machine is no hypertherm. but
this machine works, when I used the hand torch I squeeze the trigger and it cuts .25" thick steel like a hot knife cuts butter. when I hit the pulse button in the plasmac gui, after a 3 second delay the torch fires up, for about 2 seconds.
so getting ready to tackle this again.
My last attempt I wired my cnc port to the 16:1 divider, plug in the my calculated #'s and the resting number that pops up when i turn on my plasma machine screen reads 42 V. and when torch fires up it jumps up to 165 V or so. and then i get errors on the screen will post those tonight.
Last edit: 6 years 5 months ago by motal2004. Reason: more information.
6 years 5 months ago #169005 by jay1st
it does not need ot be HF de be a pilot arc.
it's not the same thing
Time to create page: 0.160 seconds
