Z axis
6 years 5 months ago #166972 by tommylight
Replied by tommylight on topic Z axis
For PlasmaC you should pick max limit + home.
Beware that the limits on the Z axis should be set as a normal axis, not as a mill, meaning min limit should be 0 and max limit should be where your home switch is, or near it.
6 years 5 months ago #167060 by motal2004
Replied by motal2004 on topic Z axis
In that note. What do I put in those empty box in the pnccofig wizard , see picture
6 years 5 months ago #167077 by motal2004
Nevermind I figured it out.
6 years 5 months ago #167133 by bbsr_5a
Replied by bbsr_5a on topic Z axis
can you add here the INI file or the Z sequence so others get a Better view what you did
Personal with more then 5 Plasmas in USE you shoudt shield your Z Axis against Spray water
a Backwards build of the Mechanic woudt be a better system but on not using 8hr a day it will be fine
the Ballscrew dont like the Waterdust mixed with Steel
6 years 5 months ago #167302 by motal2004
With a little help, I figure out that the “home switch location” is the max my z axis can travel up, Away from slats. Thus “home switch location” is where You would want the z axis to move to when once it find its home/max limit.
So I my case the “positive and negative travel” boxes where throwing me off.
The following user(s) said Thank You: Plasmaguy
6 years 5 months ago #167317 by phillc54
Replied by phillc54 on topic Z axis
Homing can take a while to get your head around, this gives a fairly good description.
linuxcnc.org/docs/2.8/html/config/ini-homing.html
Time to create page: 0.145 seconds
