- Thank you received: 2100
Up would be the correct direction.motal2004 wrote: Ok, will try that. Looks like everything is working. Just to make sure when I jog my z axis “ +” positive my torch should be moving down right?
tommylight wrote: Most probably you have run the configurator with "sudo", and that is not good, nowhere is the use of sudo mentioned in the configurator user manual.
