Z axis
6 years 5 months ago #167588 by phillc54
Replied by phillc54 on topic Z axis
Well your numbers are spot on.
You didn't add any external resistance?
6 years 5 months ago #167589 by motal2004
Replied by motal2004 on topic Z axis
Nope, no external resistors.
6 years 5 months ago #167590 by phillc54
Just try plugging in the correct numbers then change the scale and see if you can get the display down to 0v.
6 years 5 months ago #167594 by Plasmaguy
Replied by Plasmaguy on topic Z axis
You should read 0v at rest.
What issue might cause it to read other than 0?
At rest mine fluctuates 148-150v...while cutting it's 278ish ...11ga @ 100ipm, .06 cut height.
45XP book voltage calls for 128v so the THCAD10 is right there.
I ran the calibration calc with values ,
50:1 voltage divider setting
F/32 jumper on THCAD10
935.8 & 121
6 years 5 months ago #167596 by phillc54
What happens if you negate the offset? -3781.25
6 years 5 months ago #167599 by Plasmaguy
Okay thanks.. that sent it to 0 / -0.
PlasmaC is very impressive! I'm loving all of the options and layout. This will make my days much better.
