Ok, will try that. Looks like everything is working. Just to make sure when I jog my z axis “ +” positive my torch should be moving down right?
Have read this:-
Note
Base machine configuration means a complete working system without any plasma connections. All axes should be working and tuned for best performance and all home and limit switches if installed should be operating correctly.
Important
DO NOT ADD ANY PLASMA CONNECTIONS SUCH AS TORCH_ON OR ARC_OK ETC. HERE, THESE WILL BE ADDED LATER DURING THE PlasmaC CONFIGURATION.
Recommended settings for the Z axis are:
Z MINIMUM_LIMIT should be just below top of the slats with allowances for float_switch_travel and tolerance. So if your float switch took 4mm (0.0157") to activate then set your Z minimum 5mm (0.096) below the lowest slat.
Z MAXIMUM_LIMIT should be the highest you want the Z axis to travel (must not be lower than Z HOME_OFFSET)
Z HOME should be just below the maximum limit
Important
YOU SHOULD BE ABLE TO HOME YOUR MACHINE, TOUCH OFF, JOG TO SOFT LIMITS WITHOUT CRASHING AND RUN SOME TEST G-CODE WITHOUT ANY ERRORS.
When and ONLY WHEN this stage is successfully completed can you configure PlasmaC on top of your working machine.
You can create a base machine manually or you may use existing configuration helpers:
