latency and latest linuxcnc
19 Aug 2020 12:07 #178703 by andypugh
Replied by andypugh on topic latency and latest linuxcnc
Has anyone considered reading the actual LinuxCNC install docs?
  • Moderator
  • Moderator
19 Aug 2020 15:03 #178717 by tommylight
Replied by tommylight on topic latency and latest linuxcnc
Will do that promptly.
19 Aug 2020 15:25 #178723 by andypugh
The links point to files that don't exist yet in some cases. You will need the buildbot repos not the main LinuxCNC repo to get the packages.
And I don't really know what we will do about the buster/rtai packages as the buildbot seems to crash when making them.
But, conversely, my old Core2Duo gives latency <2000 (I have seen 600nS when idle) with the preempt-rt kernel.
  • Moderator
  • Moderator
19 Aug 2020 20:05 #178747 by tommylight
If i do not go out of town tomorrow, i will set up a test PC and run all this
linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html
Step by step.
Is that ok, or is there anything else?
19 Aug 2020 21:51 #178770 by Clive S
Replied by Clive S on topic latency and latest linuxcnc
Step by step.
Using the link above then using this from it www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso I get a 404 error
20 Aug 2020 07:55 #178804 by Himarc3D
Replied by Himarc3D on topic latency and latest linuxcnc
Step by step.
Philc54 wrote somewhere that’s because they are making the final adjustments to release the final 2.8.
  • Moderator
  • Moderator
20 Aug 2020 13:06 #178823 by tommylight
The ISO is in the temp folder still.
www.linuxcnc.org/temp
21 Sep 2020 11:54 #183121 by kramerda
Replied by kramerda on topic latency and latest linuxcnc
A little change to above discussion -
I just installed Iso for 2.8 Rpi4 - no problem.
Ran latency - its at the 1.2 second limit
Check the cmdtxt file and isolcpus from the instal. It l is set to =3.
1. Is there a benefit here to changing it to = 1,2,3 as discussed many times for earlier version of linuxcnc running on amd64 machines?
2. Any downside to such a change - ie things I don't know about running on the other cores of the Rpi?
3. Super noob question here - with this iso install - no need to seperately install an RT-prempt?
Thanks for clarifications.....
Dennis
  • Moderator
  • Moderator
21 Sep 2020 13:07 #183132 by tommylight
1 - should be 2,3 if i remember correctly for RPI4
2 - not noticeable downsides
3 - no.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
21 Sep 2020 13:12 #183137 by BeagleBrainz
Replied by BeagleBrainz on topic latency and latest linuxcnc
The pairs of cpus you isolate should be on the same die....at least this is the information I've seen for Intel, the reason being is that a pair of cpus share cache. Something along those lines, it made sense when I read it and damned if I can find the article.
Not 100% sure about ARM. Hopefully Nvidia wont mess with the ARM platform.
