5i25-7177 pack and go frimware
12 Sep 2020 02:55 #181814 by PMCD
5i25-7177 pack and go frimware was created by PMCD
I'm located in Australia and retrofitting a Weeke Homag BP80 and I am getting close to configuring the machine.
I have a separate power supply to TB1 and field power to TB2 and the boards are jumpered to suit.
C16 on the 7i77 is red, does this mean I have to update the firmware.
Regards
Peter
12 Sep 2020 03:07 #181815 by PCW
Replied by PCW on topic 5i25-7177 pack and go frimware
CR16 should be red when LinuxCNC is not running
You can check the installed firmware by running:
sudo mesaflash --device 5i25 --readhmid
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
12 Sep 2020 03:13 #181816 by BeagleBrainz
Replied by BeagleBrainz on topic 5i25-7177 pack and go frimware
12 Sep 2020 04:25 #181818 by PMCD
Replied by PMCD on topic 5i25-7177 pack and go frimware
Thanks, I've got a funny feeling I"m going to have a lot more?
12 Sep 2020 04:54 #181820 by PMCD
Linuxcnc is running and I still have a red light on C16 7i77.
There is no reference to the 7i77 after running
  • BeagleBrainz
  • Visitor
  • Visitor
12 Sep 2020 04:56 #181821 by BeagleBrainz
What output did you get ?
12 Sep 2020 06:05 #181825 by PMCD
It"s running on a different PC but there's nothing that mentions the 7i77
  • BeagleBrainz
  • Visitor
  • Visitor
12 Sep 2020 06:40 #181829 by BeagleBrainz
No &*(^ Sherlock........but what output are you getting ?
12 Sep 2020 07:20 #181832 by PMCD
Sorry BB I don't understand what you mean by "what output are you getting"
This is all a bit new to me but I will not let it beat me. Just trying to figure out what is causing the red C16. I read on another thread that the incorrect firmware was installed on a board, not sure if I have the same problem.
Peter
12 Sep 2020 07:27 #181834 by Aciera
Replied by Aciera on topic 5i25-7177 pack and go frimware
He means what the terminal output is when you run the command
Time to create page: 0.192 seconds
