5i25-7177 pack and go frimware
- PMCD
13 Sep 2020 02:30 #181964
by PMCD
Replied by PMCD on topic 5i25-7177 pack and go frimware
Now I just need to get rid of C16 Red.
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn3 (Out)
14 1 IOPort SSerial 0 TXData3 (Out)
2 2 IOPort SSerial 0 RXData3 (In)
15 3 IOPort SSerial 0 TXData2 (Out)
3 4 IOPort SSerial 0 RXData2 (In)
16 5 IOPort SSerial 0 TXData1 (Out)
4 6 IOPort SSerial 0 RXData1 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn6 (Out)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData6 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData5 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData4 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 3
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
- Thank you received: 5321
13 Sep 2020 02:39 #181965
Replied by PCW on topic 5i25-7177 pack and go frimware
CR16 red is expected unless LinuxCNC is running
- PMCD
13 Sep 2020 02:47 #181966
by PMCD
Do you mean linuxcnc open or running gcode.
13 Sep 2020 02:58 #181968
LinuxCNC running meaning LinuxCNC has been launched and is not in a fault or error state
- PMCD
13 Sep 2020 04:16 #181973
by PMCD
Thanks to both of you for your help.
On to Pncconfig I suppose.
- PMCD
20 Sep 2020 01:18 #182798
by PMCD
BB
Should I be able to see 7i77 field I/O on the readhmid file that I posted.
- BeagleBrainz
- Visitor
20 Sep 2020 01:27 - 20 Sep 2020 01:34 #182799
by BeagleBrainz
Replied by BeagleBrainz on topic 5i25-7177 pack and go frimware
No the field I\O is connected to smart serial ports.
So you wont see it unless you have a working config, or load hostmot2 driver via halcmd.
So you will need to run pcconf to produce a workingish config then run Linuxcnc with the config you created.
You may want to read the hm2_pci, hostmot2 & sserial man pages which are available through the documentation on the www.llinuxcnc.org page. The devs have spent a lot of time putting the docs together.
Last edit: 20 Sep 2020 01:34 by BeagleBrainz.
- PMCD
20 Sep 2020 01:44 #182800
by PMCD
I'll see if I can work that out all by myself.
- BeagleBrainz
- Visitor
20 Sep 2020 03:32 #182808
by BeagleBrainz
Just do a little bit at a time.
But pcconf will be give a basic working config, that what it was designed for.
If a dumb ass unskilled labourer can work it out, anyone should be able to.
Time to create page: 0.098 seconds
