5i25-7177 pack and go frimware
- PMCD
12 Sep 2020 07:50 #181841
by PMCD
Replied by PMCD on topic 5i25-7177 pack and go frimware
I thought that is what he meant but I can't copy and paste the file from the CNC computer to the one I'm on now and I'm not sure what I am supposed to see. It lists the I/O connections P3 and P2 at the bottom of the page.
There are no error messages.
- BeagleBrainz
- Visitor
12 Sep 2020 07:57 - 12 Sep 2020 07:58 #181845
by BeagleBrainz
Replied by BeagleBrainz on topic 5i25-7177 pack and go frimware
Try this:
copy readhmid.txt to a USB stick
then on the computer you are posting on attach readhmid.txt
Simples.........You're not a Cane Toad are you ?
sudo mesaflash --device 5i25 --readhmid > readhmid.txtthen on the computer you are posting on attach readhmid.txt
Last edit: 12 Sep 2020 07:58 by BeagleBrainz.
- PMCD
12 Sep 2020 08:47 #181856
by PMCD
I tried that command line several times but it didn't work.
No I'm a cockroach.
No I'm a cockroach.
- Thank you received: 2164
12 Sep 2020 08:52 - 12 Sep 2020 08:57 #181857
Replied by Aciera on topic 5i25-7177 pack and go frimware
The output has been redirected. Was the file created?
[edit]
readhmid.txt should be in your home directory
[edit]
Last edit: 12 Sep 2020 08:57 by Aciera.
- BeagleBrainz
- Visitor
12 Sep 2020 08:55 #181858
by BeagleBrainz
Should have created a file called readhmid.txt
Cockroach ? Me too
Cockroach ? Me too
- PMCD
12 Sep 2020 09:20 #181859
by PMCD
Finally got there, everything is easy when you know how.
I'm around Maitland area.
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
- BeagleBrainz
- Visitor
12 Sep 2020 09:33 #181861
by BeagleBrainz
Looks like you have the firmware for 2 x 7i76.
Try loading the firmware for 7i77. You can find it here:
www.mesanet.com/software/parallel/5i25.zip
The .bit files are what you load and the .pin files describe the pin allocations.
If you have a look at the ouptut for my 7i92 which is for a 7i76 it's the same.
- Clive S
- Thank you received: 486
12 Sep 2020 10:06 #181864
by Clive S
Ok what's the difference between a Cockroach and a Cane Toad ?
Replied by Clive S on topic 5i25-7177 pack and go frimware
Cockroach ? Me too
- BeagleBrainz
- Visitor
12 Sep 2020 10:31 #181867
by BeagleBrainz
Cane Toads come from Queensland & Cockroaches come from NSW. It's to do with the state Rugby League teams having a dig at each other during State of Origin. Which is a best of 3 competition between NSW & Queensland. League players and fans aren't of the same calibre as their Union counterparts.
The whole thing of Queensland being infested by cane toads was a bad bad idea.More info here:
en.wikipedia.org/wiki/Cane_toads_in_Australia
- Clive S
12 Sep 2020 10:38 #181869
by Clive S
Ok So its not a matter of how many legs each have
